Deploy on Juju storage
Charmed PostgreSQL uses the Juju storage abstraction to utilize data volume provided by different clouds while keeping the same UI/UX for end users.
- Charmed PostgreSQL 16 supports multiple storage:
archive,data,logsandtemp. - Charmed PostgreSQL 14 supports single storage:
pgdata. - Legacy PostgreSQL charm in track “latest” does not support the Juju storage abstraction.
Check the metadata.yaml for find Juju storage name and tech details:
Charmed PostgreSQL 16 storage list
storage:
archive:
type: filesystem
location: /var/snap/charmed-postgresql/common/data/archive
data:
type: filesystem
location: /var/snap/charmed-postgresql/common/var/lib/postgresql
logs:
type: filesystem
location: /var/snap/charmed-postgresql/common/data/logs
temp:
type: filesystem
location: /var/snap/charmed-postgresql/common/data/temp
Charmed PostgreSQL 16 supports multiple storage archive , data , logs and temp . See the deployment examples below.
Charmed PostgreSQL 14 storage list
storage:
pgdata:
type: filesystem
Charmed PostgreSQL 14 supports single storage pgdata attaching it on juju deploy and mounted inside the Snap common folder /var/snap/charmed-postgresql/common.
Example of 'Juju storage'
> juju deploy postgresql
> juju storage
Unit Storage ID Type Size Status Message
postgresql/0 pgdata/0 filesystem pending
> juju storage
Unit Storage ID Type Pool Size Status Message
postgresql/0 pgdata/0 filesystem rootfs 97 GiB attached
> juju show-storage pgdata/0
pgdata/0:
kind: filesystem
life: alive
status:
current: attached
since: 01 May 2025 18:47:04+02:00
persistent: false
units:
postgresql/0:
machine: "0"
life: alive
> juju ssh postgresql/0 mount | grep /var/snap/charmed-postgresql/common
/dev/sda1 on /var/snap/charmed-postgresql/common type ext4 (rw,relatime,discard,errors=remount-ro)
Deployment examples
Define the storage size
> juju deploy postgresql --storage pgdata=10G
> juju storage
postgresql/1 pgdata/1 filesystem lxd 10 GiB attached
Define the storage location
Juju supports wide list of different storage pools:
> juju create-storage-pool mystoragepool lxd
> juju storage-pools | grep mystoragepool
mystoragepool lxd
> juju deploy postgresql --storage pgdata=5G,mystoragepool
> juju storage
postgresql/2 pgdata/2 filesystem mystoragepool 5 GiB attached
Re-deploy detached storage (track 14)
To re-deploy the application with the old Juju storage, it is necessary to provide all charm/database credentials to the new charm or app.
Charmed PostgreSQL 14 uses the Juju action set-password to handle credentials:
# Note old passwords
> juju show-secret --reveal database-peers.postgresql.app
# Find old storage id:
> juju storage
# Re-deploy new app one unit only to set old passwords
> juju deploy postgresql --channel 14/stable -n 1
# Once deployed, set old passwords from old app Juju App secrets
juju run postgresql/leader set-password username=operator password=cpUJnNRJ6Qt2Hgli
juju run postgresql/leader set-password username=patroni password=0N7pKAutKCstPuvx
juju run postgresql/leader set-password username=raft password=8xSZvTLfyHpglGfI
juju run postgresql/leader set-password username=replication password=5xN9gj9uu5Um3PWB
juju run postgresql/leader set-password username=rewind password=wuEsPmsdpc6L8qhT
juju run postgresql/leader set-password username=monitoring password=AgOxXzcRD5iohE6C
# Scale down to zero units byt removing all Juju units
> juju remove-unit postgresql/1 --destroy-storage=yes
# Scale up to one unit and attach the old Juju storage
> juju add-unit postgresql --attach-storage pgdata/x
# If no issues noticed, scale to HA (3 units total)
> juju add-unit postgresql -n 2
Re-deploy detached storage (track 16)
To re-deploy the application with the old Juju storage, it is necessary to provide all charm/database credentials as Juju user secrets.
Charmed PostgreSQL 16 uses Juju user secrets to handle credentials:
# Add new Juju User secret with old password values
> juju add-secret mypgpass \
monitoring-password=oQDLAVMV1AHFZq1L \
operator-password=IXarOnndC9XKoytS \
patroni-password=vWzJZIktqi0qGMCx \
raft-password=2pALATzLJsrpAf5q \
replication-password=2bcnAQhXLrX3ekVP \
rewind-password=bBqQOXiC7whSqQbR
> juju storage
# Re-deploy new app re-using old storage and old credentials
> juju deploy postgresql \
--channel 16/candidate \
--attach-storage pgdata/5 \
--config system-users=newsecret54321id
# Grant access to new secrets for re-deployed application
> juju grant-secret mypgpass postgresql
Example: Complete old storage re-deployment (track 16)
Prepare the test data to restore later:
# Add a new model
> juju add-model teststorage
# Deploy the new postgresql to dump storage with credentials
> juju deploy postgresql --channel 16/edge --storage pgdata=5Gcompleted
Deployed "postgresql" from charm-hub charm "postgresql", revision 613 in channel 16/edge on ubuntu@24.04/stable
# Wait for deployment completed:
> juju status
postgresql/0* active idle 0 10.189.210.99 5432/tcp Primary
# Reveal the Juju secrets for the simpliest DB access:
d09v83poie738j7af4n0:
revision: 2
checksum: 9e28910800d4dd94cd655d5d5f49a9bb7e4b7fbf6dde232328e4f6734c7bdf84
owner: postgresql
label: database-peers.postgresql.app
created: 2025-05-01T22:22:07Z
updated: 2025-05-01T22:22:10Z
content:
monitoring-password: 6inFApK8IyJuJ6LG
operator-password: I8mkza6vIhD2w1Rh
patroni-password: JAYSlB3mQXi9g4fc
raft-password: eFWUOCYb1lIOpGuM
replication-password: SFBx8OL9XxXiWwcC
rewind-password: 92xT4yTniiG7OEch
# Create a test data
> PGPASSWORD=I8mkza6vIhD2w1Rh psql -h 10.189.210.99 -U operator -d postgres -c "create table a (id int);"
CREATE TABLE
> PGPASSWORD=I8mkza6vIhD2w1Rh psql -h 10.189.210.99 -U operator -d postgres -c "\d"
List of relations
Schema | Name | Type | Owner
public | a | table | operator
(1 row)
# Check the storage status
> juju storage
postgresql/0 pgdata/0 filesystem lxd 5.0 GiB attached
# Remove the old application keeping the storage:
> juju remove-application postgresql --destroy-storage=false
WARNING This command will perform the following actions:
will remove application postgresql
- will remove unit postgresql/0
- will detach storage pgdata/0
Continue [y/N]? y
# Check the status (app and secrets are gone, but storage stays):
> juju status
teststorage lxd localhost/localhost 3.6.5 unsupported 00:28:44+02:00
Model "admin/teststorage" is empty.
> juju secrets
ID Name Owner Rotation Revision Last updated
> juju storage
pgdata/0 filesystem lxd 5.0 GiB detached
Re-deploy the postgresql application reusing storage pgdata/0 :
# Create a new Juju User secret
monitoring-password=6inFApK8IyJuJ6LG \
operator-password=I8mkza6vIhD2w1Rh \
patroni-password=JAYSlB3mQXi9g4fc \
raft-password=eFWUOCYb1lIOpGuM \
replication-password=SFBx8OL9XxXiWwcC \
rewind-password=92xT4yTniiG7OEch
secret:d09vcn1oie738j7af4ng
# Re-deploy app with old storage and old passwords
--channel 16/edge \
--attach-storage pgdata/0 \
--config system-users=d09vcn1oie738j7af4ng
# Grant new application access to manually created Juju User secret
> juju status
postgresql/1* active idle 1 10.189.210.179 5432/tcp Primary
# Check the old data access once deployment completed (use new App IP!):
> PGPASSWORD=I8mkza6vIhD2w1Rh psql -h 10.189.210.179 -U operator -d postgres -c "\d"
List of relations
(1 row)
# Old storage re-used:
> juju storage
postgresql/1 pgdata/0 filesystem lxd 5.0 GiB attached
