How to deploy on Sunbeam
Duration : Up to 60 minutes depending on internet download speed.
This guide goes through the steps for setting up Sunbeam and deploying Charmed PostgreSQL.
- A physical or virtual machine running Ubuntu 22.04+
- If you’d like to follow this guide in an isolated test environment, you can launch a Multipass instance.
- Hardware requirements depend on planned deployment size.
- Recommended: 8 CPU cores, 32GB RAM, 100GB of storage
- Minimum: See the requirements listed in the Sunbeam documentation
Steps
- Install and bootstrap Sunbeam
- Enable OpenStack Images Auto-sync
- Set up Juju inside an OpenStack bastion
- Deploy Charmed PostgreSQL
- (Optional) Access the OpenStack dashboard
Follow the official OpenStack guide: Single-node deployment.
Pay attention to the Caution and Note sections - the /etc/hosts will require a manual fqdn fix.
Follow the official Images Sync guide to enable auto-sync and wait for the image 22.04 to be downloaded.
Follow the MicroStack guide Manage workloads with Juju from the beginning, and stop after the section “Create a Juju controller”.
To summarize, the relevant sections are:
- Set up the bastion
- Install and configure the Juju client
- Create a Juju controller
Add a model if you don’t have one already, and deploy a PostgreSQL cluster. Use the -n flag to specify number of units.
juju add-model postgresql
juju deploy postgresql --base ubuntu@22.04 -n 3
Sample output of juju status --watch 1s:
postgresql my-controller sunbeam/RegionOne 3.5.4 unsupported 19:42:44Z
postgresql 14.12 active 3 postgresql 14/stable 468 no
postgresql/0* active idle 0 192.168.122.211 5432/tcp Primary
postgresql/1 active idle 1 192.168.122.226 5432/tcp
postgresql/2 active idle 2 192.168.122.14 5432/tcp
0 started 192.168.122.211 3f0a331c-bc08-4bae-af22-44087a7b74d6 ubuntu@22.04 nova ACTIVE
1 started 192.168.122.226 e6e908f8-0da1-4440-9bbd-9f1c1bc780df ubuntu@22.04 nova ACTIVE
2 started 192.168.122.14 6f9ad7cd-2a9d-435e-a6d8-3e39bf2218cd ubuntu@22.04 nova ACTIVE
Follow the official guide: Accessing the OpenStack dashboard.
When using a Multipass VM, you may need to manually route OpenStack IPs. For example:
sudo ip route add 10.10.10.0/24 via 10.76.203.210
where 10.76.203.210 is the IP of the Multipass VM and 10.10.10.0 is the network returned by sunbeam dashboard-url.
The image below is an example of the OpenStack dashboard view (bastion + juju controller + 3 postgresql nodes):
To learn more about deploying and operating PostgreSQL, see the Charmed PostgreSQL tutorial.
