How to deploy on AWS EC2
Amazon Web Services is a popular subsidiary of Amazon that provides on-demand cloud computing platforms on a metered pay-as-you-go basis. Access the AWS web console at console.aws.amazon.com.
- Install AWS and Juju tooling
- Bootstrap Juju controller on AWS EC2
- Deploy charms
- Expose database (optional)
- Clean up
Install Juju via snap:
sudo snap install juju
Follow the installation guides for:
- AWs CLI - the Amazon Web Services CLI
To check they are all correctly installed, you can run the commands demonstrated below with sample outputs:
~$ juju version
3.5.4-genericlinux-amd64
~$ aws --version
aws-cli/2.13.25 Python/3.11.5 Linux/6.2.0-33-generic exe/x86_64.ubuntu.23 prompt/off
Authenticate
Create an IAM account (or use legacy access keys) to operate AWS EC2:
mkdir -p ~/.aws && cat <<- EOF > ~/.aws/credentials.yaml
credentials:
aws:
NAME_OF_YOUR_CREDENTIAL:
auth-type: access-key
access-key: SECRET_ACCESS_KEY_ID
secret-key: SECRET_ACCESS_KEY_VALUE
EOF
Add AWS credentials to Juju:
juju add-credential aws -f ~/.aws/credentials.yaml
Bootstrap Juju controller (check all supported configuration options):
juju bootstrap aws
Output example
> juju bootstrap aws
Creating Juju controller "aws-us-east-1" on aws/us-east-1
Looking for packaged Juju agent version 3.5.4 for amd64
Located Juju agent version 3.5.4-ubuntu-amd64 at https://juju-dist-aws.s3.amazonaws.com/agents/agent/3.5.4/juju-3.5.4-linux-amd64.tgz
Launching controller instance(s) on aws/us-east-1...
- i-0f4615983d113166d (arch=amd64 mem=8G cores=2)
Installing Juju agent on bootstrap instance
Waiting for address
Attempting to connect to 54.226.221.6:22
Attempting to connect to 172.31.20.34:22
Connected to 54.226.221.6
Running machine configuration script...
Bootstrap agent now started
Contacting Juju controller at 54.226.221.6 to verify accessibility...
Bootstrap complete, controller "aws-us-east-1" is now available
Controller machines are in the "controller" model
Now you can run
juju add-model <model-name>
to create a new model to deploy workloads.
You can check the AWS EC2 instance availability (ensure the right AWS region chosen!):
Create a new Juju model:
juju add-model welcome
(Optional) Increase the debug level if you are troubleshooting charms:
juju model-config logging-config='<root>=INFO;unit=DEBUG'
Deploy charms
The following command deploys PostgreSQL and Data-Integrator (the charm to request a test DB):
juju deploy postgresql
juju deploy data-integrator --config database-name=test123
juju relate postgresql data-integrator
Check the status:
> juju status --relations
welcome aws-us-east-1 aws/us-east-1 3.5.4 unsupported 13:33:05+02:00
data-integrator active 1 data-integrator latest/stable 41 no
postgresql 14.12 active 1 postgresql 14/stable 468 no
data-integrator/0* active idle 1 50.19.16.57
postgresql/0* active idle 0 54.224.41.249 5432/tcp Primary
0 started 54.224.41.249 i-0f374435695ffc54c ubuntu@22.04 us-east-1b running
1 started 50.19.16.57 i-061e0d10d36c8cffe ubuntu@22.04 us-east-1a running
data-integrator:data-integrator-peers data-integrator:data-integrator-peers data-integrator-peers peer
postgresql:database data-integrator:postgresql postgresql_client regular
postgresql:database-peers postgresql:database-peers postgresql_peers peer
postgresql:restart postgresql:restart rolling_op peer
postgresql:upgrade postgresql:upgrade upgrade peer
Once deployed, request the credentials for your newly bootstrapped PostgreSQL database.
For Juju 2.9 use:
juju run-action --wait data-integrator/leader get-credentials
and for newer Juju 3+ use:
The output example:
postgresql:
data: '{"database": "test123", "external-node-connectivity": "true", "requested-secrets":
"[\"username\", \"password\", \"tls\", \"tls-ca\", \"uris\"]"}'
database: test123
endpoints: 172.31.40.178:5432
password: rmnk0AO4jICAixCL
uris: postgresql://relation-4:rmnk0AO4jICAixCL@172.31.40.178:5432/test123
username: relation-4
version: "14.12"
At this point, you can access your DB inside AWS using the internal IP address. All further Juju applications will use the database through the internal network:
> psql postgresql://relation-4:rmnk0AO4jICAixCL@172.31.40.178:5432/test123
psql (15.6 (Ubuntu 15.6-0ubuntu0.23.10.1), server 14.12 (Ubuntu 14.12-0ubuntu0.22.04.1))
Type "help" for help.
test123=>
From here you can use/scale/backup/restore/refresh your newly deployed Charmed PostgreSQL.
If necessary to access DB from outside of AWS (warning: opening ports to public is risky) open the AWS firewall using the simple juju expose functionality:
juju expose postgresql
Once exposed, you can connect your database using the same credentials as above (Important: this time use the EC2 Public IP assigned to the PostgreSQL instance):
> juju status postgresql
> psql postgresql://relation-4:rmnk0AO4jICAixCL@54.224.41.249:5432/test123
test123=>
To close the public access run:
juju unexpose postgresql
Clean up
Always clean AWS resources that are no longer necessary - they could be costly!
To destroy the Juju controller and remove AWS instance (warning: all your data will be permanently removed):
> juju controllers
Controller Model User Access Cloud/Region Models Nodes HA Version
aws-us-east-1* - admin superuser aws/us-east-1 1 1 none 3.5.4
> juju destroy-controller aws-us-east-1 --destroy-all-models --destroy-storage --force
Next, check and manually delete all unnecessary AWS EC2 instances, to show the list of all your EC2 instances run the following command (make sure the correct region used!):
aws ec2 describe-instances --region us-east-1 --query "Reservations[].Instances[*].{InstanceType: InstanceType, InstanceId: InstanceId, State: State.Name}" --output table
Output example
| DescribeInstances |
| InstanceId | InstanceType | State |
| i-0f374435695ffc54c| m7i.large | terminated |
| i-0e1e8279f6b2a08e0| m7i.large | terminated |
| i-061e0d10d36c8cffe| m7i.large | terminated |
| i-0f4615983d113166d| m7i.large | terminated |
List your Juju credentials:
> juju credentials
Client Credentials:
Cloud Credentials
aws NAME_OF_YOUR_CREDENTIAL
Remove AWS EC2 CLI credentials from Juju:
> juju remove-credential aws NAME_OF_YOUR_CREDENTIAL
Finally, remove AWS CLI user credentials (to avoid forgetting and leaking):
rm -f ~/.aws/credentials.yaml
If you expect having several concurrent connections frequently, it is highly recommended to deploy PgBouncer alongside PostgreSQL. For more information, read our explanation about Connection pooling.
