Reference > Release Notes > All revisions > Revision 173/174/175/176
Revisions 173/174/175/176
18 May, 2024
Dear community,
We’d like to announce that Canonical’s newest Charmed PgBouncer operator has been published in the 1/stable channel
AMD64 | ARM64 |
174 (jammy ) 175 ( focal ) |
173 (jammy ) 176 ( focal ) |
- New ARM support! [#196]
- Exposure of all endpoints via data-integrator [#137][DPE-3451]
- Add TLS support [#137][DPE-3452]
- All the functionality from previous revisions
Bugfixes
- [DPE-4221] Recreate auth_query on backend rerelation in #224
- [DPE-4202] data_platform_libs update in #207
- [DPE-3658] Add subordinate charms test in #195
- [DPE-3050] Template config in #159
- [DPE-3602] Fixed charm restart in #155
- [DPE-3535] Rerender config from secrets during upgrade in #150
- [DPE-3184] Update secrets implementation in #145
- [MISC] Fix secret keys in #148
- [MISC] Update Charmed PostgreSQL SNAP in #222
GitHub Releases provide a detailed list of bugfixes, PRs, and commits for each revision.
Inside the charms
- Charmed PgBouncer ships the latest PgBouncer
1.21.0-0ubuntu0.22.04.1~ppa1
- The Prometheus pgbouncer-exporter is “0.7.0-0ubuntu0.22.04.1~ppa1”
- VM charms based on Charmed PostgreSQL SNAP (Ubuntu LTS
22.04.4
) revision 113 - Subordinate charms support LTS
22.04
and20.04
only
Technical notes
- Upgrade via
juju refresh
is possible from revision 81+. - Please check the external components requirements
- Note: juju 3.1.6 doesn’t report when
pre-upgrade-check
action fails. Therefore, it is recommended to redeploy pgbouncer charm on Juju 3.1.7+ - Use this operator together with the Charmed PostgreSQL operator
Contact us
Charmed PgBouncer is an open source project that warmly welcomes community contributions, suggestions, fixes, and constructive feedback.
