Cleanup and extra info
Remove Charmed OpenSearch and Juju
Warning: when you remove Charmed OpenSearch as shown below you will lose all the data in your cluster. Furthermore, when you remove Juju as shown below you will lose access to any other applications you have hosted on Juju.
To remove Charmed OpenSearch and the model it is hosted on, run this command:
juju destroy-model tutorial --destroy-storage --force --no-wait
Next step is to remove the Juju controller. You can see all of the available controllers by entering juju controllers
. To remove the controller enter:
juju destroy-controller opensearch-demo
Finally to remove Juju altogether, enter:
sudo snap remove juju --purge
Next Steps
In this tutorial we’ve successfully deployed OpenSearch, added/removed units from the cluster, added/removed users to/from the database, and even enabled and disabled TLS. You may now keep your Charmed OpenSearch deployment running and write to the database or remove it entirely using the steps in Remove Charmed Opensearch and Juju. If you’re looking for what to do next you can:
- Check out other charms on charmhub.io
- Give us your feedback.
- Contribute to the code base
