Transport Layer Security (TLS)
TLS is used to encrypt data exchanged between two applications; it secures data transmitted over the network. Typically, enabling TLS within a highly available database, and between a highly available database and client/server applications, requires domain-specific knowledge and a high level of expertise. Fortunately, the domain-specific knowledge has been encoded into Charmed OpenSearch. This means enabling TLS on Charmed Opensearch is easily available and requires minimal effort on your end.
TLS is mandatory for OpenSearch deployments because nodes in an OpenSearch cluster require TLS to communicate with each other securely. Therefore, the OpenSearch charm will be in a blocked state until TLS is configured. Since TLS certificates are already being prepared for internal communication between OpenSearch nodes, we make use of the same certificate for external communications with the REST API. Therefore, TLS must be configured before connecting to the charm.
TLS is enabled via relations, by relating Charmed OpenSearch to the TLS Certificates Charm. The TLS Certificates Charm centralises TLS certificate management in a consistent manner and handles providing, requesting, and renewing TLS certificates.
Configure TLS
Before enabling TLS on Charmed OpenSearch we must first deploy the tls-certificates-operator
charm:
juju deploy tls-certificates-operator
Wait until the tls-certificates-operator
is ready to be configured. When it is ready to be configured watch -c juju status --color
will show:
tutorial opensearch-demo localhost/localhost 2.9.42 unsupported 15:16:43Z
opensearch blocked 1 opensearch edge 22 no Waiting for TLS to be fully configured...
tls-certificates-operator blocked 1 tls-certificates-operator stable 22 no Configuration options missing: ['certificate', 'ca-certificate']
opensearch/0* blocked idle 0 10.180.162.97 Waiting for TLS to be fully configured...
tls-certificates-operator/0* blocked idle 1 10.180.162.44 Configuration options missing: ['certificate', 'ca-certificate']
0 started 10.180.162.97 juju-3305a8-0 jammy Running
1 started 10.180.162.44 juju-3305a8-1 jammy Running
Now we can configure the TLS certificates. Configure the tls-certificates-operator
to use self signed certificates:
juju config tls-certificates-operator generate-self-signed-certificates="true" ca-common-name="Tutorial CA"
Note: this tutorial uses self-signed certificates; self-signed certificates should not be used in a production cluster. To set the correct certificates, see the TLS operator documentation.
Enable TLS
After configuring the certificates juju status
will show the status of tls-certificates-operator
as active. To enable TLS on Charmed OpenSearch, relate the two applications:
juju relate tls-certificates-operator opensearch
The OpenSearch service will start, and the output of juju status --relations
should now resemble the following:
tutorial opensearch-demo localhost/localhost 2.9.42 unsupported 15:24:18Z
opensearch active 1 opensearch edge 22 no
tls-certificates-operator active 1 tls-certificates-operator stable 22 no
opensearch/0* active idle 0 10.180.162.97
tls-certificates-operator/0* active idle 1 10.180.162.44
opensearch:opensearch-peers opensearch:opensearch-peers opensearch_peers peer
opensearch:service opensearch:service rolling_op peer
tls-certificates-operator:certificates opensearch:certificates tls-certificates regular
tls-certificates-operator:replicas tls-certificates-operator:replicas tls-certificates-replica peer
Next Steps
The next stage in this tutorial is about connecting to and using the OpenSearch charm, and can be found here.
