How to restore a local backup
This is a guide on how to restore a locally made backup.
To restore a backup that was made from a different cluster, (i.e. cluster migration via restore), see How to migrate to a new cluster.
All commands are written for juju >= v.3.1.7
For more information, check the Juju Release Notes.
- Access to an S3-compatible storage
- Configured settings for the S3-compatible storage
- Existing backups in your S3-compatible storage
List backups
To view the available backups to restore, use the command list-backups:
juju run opensearch/leader list-backups
Running operation 335 with 1 task
- task 336 on unit-opensearch-0
Waiting for task 336...
backups: |2-
backup-id | backup-status
2024-04-25T21:09:38Z | success
2024-04-25T21:16:26Z | success
Restore backup
To restore a backup from the previously returned list, run the restore command and pass the corresponding backup-id:
juju run opensearch/leader restore backup-id="2024-04-25T21:16:26Z"
Running operation 339 with 1 task
- task 340 on unit-opensearch-0
Waiting for task 340...
backup-id: "2024-04-25T21:16:26Z"
closed-indices: '{''.opensearch-sap-log-types-config'', ''series_index'', ''.plugins-ml-config''}'
status: Restore is complete
Your restore has been restored.
If the restore takes too long, the Juju CLI above will time out but the juju status
command will provide a view if the charm is still running the restore action or not.
