A Charmed OpenSearch backup can be stored on any S3-compatible storage. S3 access and configurations are managed with the s3-integrator charm.
This guide will teach how to extend the current juju actions to execute and manage backups in large deployment setups.
All commands are written for juju >= v.3.1.7
For more information, check the Juju Release Notes.
In large deployments, the juju application with the role of “main orchestrator” should be related with S3 integrator.
Configure S3
Follow the backup guide to setup an appropriate S3 target for this task.
Integrate with Charmed OpenSearch
The integration between OpenSearch in a large deployment setup and s3-integrator should happen only in the active cluster manager. The user should identify which juju application is currently the active cluster and relate it to s3-integrator.
In the example:
test-large-deployment-upgrades-jbmj localhost-localhost localhost/localhost 3.4.2 unsupported 19:18:24+02:00
failover active 2 opensearch 2/edge 86 no
main active 1 opensearch 2/edge 86 no
opensearch active 3 opensearch 2/edge 86 no
self-signed-certificates active 1 self-signed-certificates latest/stable 72 no
failover/0 active idle 0 10.173.208.184 9200/tcp
failover/1* active idle 1 10.173.208.236 9200/tcp
main/0* active idle 2 10.173.208.204 9200/tcp
opensearch/0 active idle 4 10.173.208.14 9200/tcp
opensearch/1 active idle 5 10.173.208.128 9200/tcp
opensearch/2* active idle 6 10.173.208.36 9200/tcp
self-signed-certificates/0* active idle 3 10.173.208.103
0 started 10.173.208.184 juju-b0cc19-0 ubuntu@22.04 Running
1 started 10.173.208.236 juju-b0cc19-1 ubuntu@22.04 Running
2 started 10.173.208.204 juju-b0cc19-2 ubuntu@22.04 Running
3 started 10.173.208.103 juju-b0cc19-3 ubuntu@22.04 Running
4 started 10.173.208.14 juju-b0cc19-4 ubuntu@22.04 Running
5 started 10.173.208.128 juju-b0cc19-5 ubuntu@22.04 Running
6 started 10.173.208.36 juju-b0cc19-6 ubuntu@22.04 Running
The role of each juju application is:
- “opensearch” application: non-cluster manager and data-only app
- “failover” application: cluster manager app but does not contain the elected cluster manager unit
- “main” application: cluster manager app that contains the cluster manager.
To integrate with S3, after the S3 configuration has been done as described above, run the following command:
juju integrate s3-integrator main
Interacting with Backups
The commands described in the previous documentation for backup creation, backup restore, cluster migration or listing backups are still valid and can be executed in large deployments on the main-orchestrator cluster.
In the example above, the the commands will be successful if executed as follows:
# Create a backup
juju run main/leader create-backup
# List available backups
juju run main/leader list-backups
# Recover from an existing backup
juju run main/leader juju run opensearch/leader restore backup-id=<ID>
