How to enable JWT Authentication
This document shows how to enable authentication with JSON Web Tokens (JWT) in OpenSearch.
Prerequisites:
- A running deployment of Opensearch on VM with minimum charm revision 275 (22.04) or 276 (24.04)
- A valid JSON Web Token for testing, issued by the JWT provider of your choice
- The signing-key with which the JWT was signed
The generation of JWT’s is not part of the scope of this document.
Deploy and configure JWT integrator
The configuration for JWT authentication is provided to OpenSearch via the JWT integrator charm.
Deploy the charm:
juju deploy jwt-integrator --channel 1/edge
After the deployment has settled, the charm will be in blocked status because of missing configuration. You can check this with juju status
opensearch dev-controller localhost/localhost 3.6.8 unsupported 12:02:14Z
jwt-integrator blocked 1 jwt-integrator 1/edge 1 no Missing 'signing-key' or 'roles-key' con... Run `status-detail`: 0 action required; 1 additional statuses.
opensearch active 3 opensearch 2/edge 276 no
self-signed-certificates active 1 self-signed-certificates 1/stable 317 no
jwt-integrator/0* blocked idle 3 10.65.50.163 Missing 'signing-key' or 'roles-key' con... Run `status-detail`: 0 action required; 1 additional statuses.
opensearch/0* active idle 0 10.65.50.55 9200/tcp
opensearch/1 active idle 1 10.65.50.63 9200/tcp
opensearch/2 active idle 2 10.65.50.37 9200/tcp
self-signed-certificates/0* active idle 4 10.65.50.79
Now, configure the JWT parameters to JWT integrator. First, create a secret containing the signing-key:
juju add-secret jwt-key signing-key="<your-signing-key>"
Take a note of the secret URI for later.
Now grant permissions for the secret to JWT integrator:
juju grant-secret jwt-key jwt-integrator
Next step is to provide the secret URI as configuration option:
juju config jwt-integrator signing-key=<your-secret-URI>
Configure all other configuration options, according to your JWT provider:
juju config jwt-integrator roles-key=role subject-key=user jwt-url-parameter=jwt ...
Enable JWT in OpenSearch
Now it’s time to enable JWT authentication in OpenSearch. This is done by integrating the JWT integrator with OpenSearch:
juju integrate jwt-integrator opensearch
After a few moments, OpenSearch has applied the provided configuration and updated its security plugin. Now you can query Opensearch with your JWT:
curl --header "Authorization: Bearer <your-jwt-here>" -XGET "https://<ip-address>:9200/_cat/nodes" -k
Large Deployments
If you have an OpenSearch large deployments cluster, it is required to integrate the JWT integrator with the main-orchestrator of your large deployment.
Check which of your deployed OpenSearch applications is the main-orchestrator by checking the integrations
section of juju status
opensearch-main:peer-cluster-orchestrator opensearch-data:peer-cluster peer_cluster regular
Now integrate the JWT integrator with this application:
juju integrate jwt-integrator opensearch-main
If the wrong application of your large deployments is integrated with the JWT integrator, you will see a blocked
status:
jwt-integrator active 1 jwt-integrator 1/edge 1 no
opensearch-data blocked 3 opensearch 3 no JWT relation must be created with Main-cluster-orchestrator
opensearch-failover active 1 opensearch 1 no
opensearch-main active 1 opensearch 2 no
self-signed-certificates active 1 self-signed-certificates latest/stable 264 no
Enabling JWT authentication with OpenSearch Dashboards
To use JWT authentication in the OpenSearch Dashboards UI, all you need to do is integrate the JWT integrator with Opensearch Dashboards:
juju integrate jwt-integrator opensearch-dashboards
Make sure you have configured the configuration option jwt-url-parameter
to the JWT integrator:
juju config jwt-integrator jwt-url-parameter="jwt"
After a few moments, you can access it by adding your JWT as a URL parameter in the Browser like this:
http://<ip-address>:5601?jwt=<your-jwt>
