Charmed Opensearch Dashboards | Home
Charmed OpenSearch Dashboards Documentation
OpenSearch Dashboards is a frontend application that lets you visualize data stored in an OpenSearch database. Charmed OpenSearch Dashboard is the adaptation of the OpenSearch Dashboards user interface to the Juju environment.
OpenSearch is a distributed search and analytics engine that supports various use cases, from implementing a search box on a website to analyzing security data for threat detection.
The OpenSearch Dashboards and OpenSearch operators are available for physical/virtual machines.
In this documentation
Tutorials
Get started - a hands-on introduction to using the Charmed OpenSearch Dashboards operator for new users
How-to guides
Step-by-step guides covering key operations and common tasks
Project and community
Charmed MongoDB is an open source project that warmly welcomes community contributions, suggestions, fixes, and constructive feedback.
Licensing & Trademark
The Charmed OpenSearch Dashboards Operator is free software, distributed under the Apache Software License, version 2.0.
All of the software in the OpenSearch project is released under the Apache Software License, version 2.0
Navigation
Navigation
Level Path Navlink
1 tutorial Tutorial
2 t-overview Introduction
2 t-set-up 1. Set up the environment
2 t-deploy 2. Deploy
2 t-encryption 3. Enable TLS
2 t-access 4. Interactive Access
2 t-cleanup 5. Clean up the environment
1 how-to How To
2 h-deploy Deploy
2 h-scale Scale up/down
2 h-db-connect Connect to OpenSearch
2 h-change-credentials Change credentials
2 h-encryption Enable TLS
2 h-jwt-authentication Enable JWT Authentication
2 h-access-oauth Access Using OAuth
2 h-monitoring Monitoring COS
3 h-monitoring-enable Enable COS
1 reference Reference
2 release-notes Release notes
