Charm Testing reference
There are a lot of test types available and most of them are well applicable for Charmed MySQL K8s. Here is a list prepared by Canonical:
- Smoke test
- Unit tests
- Integration tests
- System test
- Performance test
Note: below examples are written for Juju 3.x, but Juju 2.9 is supported as well.
Please adopt the juju run ... commands as juju run-action ... --wait for Juju 2.9.
Smoke test
Complexity: trivial
Speed: fast
Goal: ensure basic functionality works over short amount of time.
Setup an Juju 3.x environment, deploy DB with test application and start “continuous write” test:
juju add-model smoke-test
juju deploy mysql-k8s --trust --channel 8.0/edge --config profile=testing
juju scale-application mysql-k8s 3 # (optional)
juju deploy mysql-test-app --channel latest/edge
juju relate mysql-test-app mysql-k8s:database
# Make sure random data inserted into DB by test application:
juju run mysql-test-app/leader get-inserted-data
# Start "continuous write" test:
juju run mysql-test-app/leader start-continuous-writes
export password=$(juju run mysql-k8s/leader get-password username=root | yq '.. | select(. | has("password")).password')
watch -n1 -x juju ssh --container mysql mysql-k8s/leader "mysql -h 127.0.0.1 -uroot -p${password} -e \"select count(*) from continuous_writes_database.data\""
# Watch the counter is growing!
Expected results:
- mysql-test-app continuously inserts records in database
continuous_writes_databasetabledata. - the counters (amount of records in table) are growing on all cluster members
Hints:
# Stop "continuous write" test
juju run mysql-test-app/leader stop-continuous-writes
# Truncate "continuous write" table (delete all records from DB)
juju run mysql-test-app/leader clear-continuous-writes
Unit tests
Please check the “Contributing” guide and follow tox run -e unit examples there.
Integration tests
Please check the “Contributing” guide and follow tox run -e integration examples there.
System test
Please check/deploy the charm mysql-bundle (Git). It deploy and test all the necessary parts at once.
Performance test
Refer to the sysbench documentation.
