Charmed MySQL K8s How to | Deploy on EKS
How to deploy on EKS
Amazon Elastic Kubernetes Service (EKS) is a popular, fully automated Kubernetes service. To access the EKS Web interface, go to console.aws.amazon.com/eks/home.
Install EKS and Juju tooling
Install Juju and the kubectl CLI tools via snap:
sudo snap install juju
sudo snap install kubectl --classic
Follow the installation guides for:
  • eksctl - the Amazon EKS CLI
  • AWs CLI - the Amazon Web Services CLI
To check they are all correctly installed, you can run the commands demonstrated below with sample outputs:
> juju version
3.1.7-ubuntu-amd64
> kubectl version --client
Client Version: v1.28.2
Kustomize Version: v5.0.4-0.20230601165947-6ce0bf390ce3
> eksctl info
eksctl version: 0.159.0
kubectl version: v1.28.2
> aws --version
aws-cli/2.13.25 Python/3.11.5 Linux/6.2.0-33-generic exe/x86_64.ubuntu.23 prompt/off
Authenticate
Create an IAM account (or use legacy access keys) and login to AWS:
> aws configure
AWS Access Key ID [None]: SECRET_ACCESS_KEY_ID
AWS Secret Access Key [None]: SECRET_ACCESS_KEY_VALUE
Default region name [None]: eu-west-3
Default output format [None]:
> aws sts get-caller-identity
    "UserId": "1234567890",
    "Account": "1234567890",
    "Arn": "arn:aws:iam::1234567890:root"
Create a new EKS cluster
Export the deployment name for further use:
export JUJU_NAME=eks-$USER-$RANDOM
This following examples in this guide will use the location eu-west-3 and K8s v.1.27 - feel free to change this for your own deployment.
Sample cluster.yaml:
> cat <<-EOF > cluster.yaml
apiVersion: eksctl.io/v1alpha5
kind: ClusterConfig
metadata:
    region: eu-west-3
    version: "1.27"
iam:
  withOIDC: true
addons:
- name: aws-ebs-csi-driver
  wellKnownPolicies:
    ebsCSIController: true
nodeGroups:
    - name: ng-1
      minSize: 3
      maxSize: 5
      iam:
        attachPolicyARNs:
        - arn:aws:iam::aws:policy/AmazonEKSWorkerNodePolicy
        - arn:aws:iam::aws:policy/AmazonEKS_CNI_Policy
        - arn:aws:iam::aws:policy/AmazonEC2ContainerRegistryReadOnly
        - arn:aws:iam::aws:policy/AmazonSSMManagedInstanceCore
        - arn:aws:iam::aws:policy/AmazonS3FullAccess
      instancesDistribution:
        maxPrice: 0.15
        instanceTypes: ["m5.xlarge", "m5.2xlarge"] # At least two instance types should be specified
        onDemandBaseCapacity: 0
        onDemandPercentageAboveBaseCapacity: 50
        spotInstancePools: 2
EOF
Bootstrap EKS cluster with the following command:
eksctl create cluster -f cluster.yaml
Sample output:
2023-10-12 11:13:58 [ℹ]  using region eu-west-3
2023-10-12 11:13:59 [ℹ]  using Kubernetes version 1.27
2023-10-12 11:40:00 [✔]  EKS cluster "eks-taurus-27506" in "eu-west-3" region is ready
Bootstrap Juju on EKS
There is a known bug for juju v.3.1 users:
Add Juju k8s clouds:
juju add-k8s $JUJU_NAME
Bootstrap Juju controller:
juju bootstrap $JUJU_NAME
Create a new Juju model (k8s namespace)
juju add-model welcome
[Optional] Increase DEBUG level if you are troubleshooting charms
juju model-config logging-config='<root>=INFO;unit=DEBUG'
Deploy charms
The following commands deploy and integrate the MySQL K8s Bundle and MySQL Test App:
juju deploy mysql-k8s-bundle --channel 8.0/edge --trust
juju deploy mysql-test-app
juju integrate mysql-test-app mysql-k8s:database
To track the status of the deployment, run
juju status --watch 1s
Display deployment information
Display information about the current deployments with the following commands:
> juju controllers
Controller         Model    User   Access     Cloud/Region      Models  Nodes  HA  Version
eks-taurus-27506*  welcome  admin  superuser  eks-taurus-27506       2      1   -  2.9.45
> kubectl cluster-info
Kubernetes control plane is running at https://AAAAAAAAAAAAAAAAAAAAAAA.gr7.eu-west-3.eks.amazonaws.com
CoreDNS is running at https://AAAAAAAAAAAAAAAAAAAAAAA.gr7.eu-west-3.eks.amazonaws.com/api/v1/namespaces/kube-system/services/kube-dns:dns/proxy
> eksctl get cluster -A
NAME			    REGION		EKSCTL   CREATED
eks-taurus-27506	eu-west-3	True
> kubectl get node
NAME                                           STATUS   ROLES    AGE   VERSION
ip-192-168-14-61.eu-west-3.compute.internal    Ready    <none>   19m   v1.27.5-eks-43840fb
ip-192-168-51-96.eu-west-3.compute.internal    Ready    <none>   19m   v1.27.5-eks-43840fb
ip-192-168-78-167.eu-west-3.compute.internal   Ready    <none>   19m   v1.27.5-eks-43840fb
Clean up
Always clean EKS resources that are no longer necessary - they could be costly!
To clean the EKS cluster, resources and juju cloud, run the following commands:
juju destroy-controller $JUJU_NAME --yes --destroy-all-models --destroy-storage --force
juju remove-cloud $JUJU_NAME
List all services and then delete those that have an associated EXTERNAL-IP value (e.g. load balancers):
kubectl get svc --all-namespaces
kubectl delete svc <service-name>
Next, delete the EKS cluster (source: Deleting an Amazon EKS cluster)
eksctl delete cluster <cluster_name> --region eu-west-3 --force --disable-nodegroup-eviction
Finally, remove AWS CLI user credentials (to avoid forgetting and leaking):
rm -f ~/.aws/credentials
Thank you for this. I created an AWS root account and succumbed to the constant warnings to create an IAM user rather than using the root user.
Getting the user, groups, roles, permissions and associations to the EKS cluster must be wrong for me.
If you can, can you add some advice on that aspect of the process please?
Dear @jjflynn ,
Thank you for the feedback and interest to our project!
The proper (and secure) accounts management deserves the dedicated cloud-specific documentation.
In nutshell you exactly need to follow the advise and create IAM user for AWS CLI, a good starting points can be:
I am sure AWS/EKS support can help you there with pleasure!
