Configure S3 for AWS
Charmed MySQL backup can be stored on any S3 compatible storage. The S3 access and configurations are managed with the s3-integrator charm. Deploy and configure the s3-integrator charm for AWS S3 (click here to backup on Ceph via RadosGW):
juju deploy s3-integrator
juju run s3-integrator/leader sync-s3-credentials access-key=<access-key-here> secret-key=<secret-key-here>
juju config s3-integrator \
endpoint="https://s3.amazonaws.com" \
bucket="mysql-test-bucket-1" \
path="/mysql-test" \
region="us-west-2"
The amazon S3 endpoint must be specified as s3.<region>.amazonaws.com within the first 24 hours of creating the bucket. For older buckets, the endpoint s3.amazonaws.com can be used.
See this post for more information.
To pass these configurations to Charmed MySQL, relate the two applications:
juju integrate s3-integrator mysql
You can create/list/restore backups now:
juju run mysql/leader list-backups
juju run mysql/leader create-backup
juju run mysql/leader restore backup-id=<backup-id-here>
You can also update your S3 configuration options after relating, using:
juju config s3-integrator <option>=<value>
The s3-integrator charm accepts many configurations - enter whatever configurations are necessary for your S3 storage.
