Note: All commands are written for juju >= v3.0
How to restore a local backup
This is a How-To for performing a basic restore (restoring a locally made backup). To restore a backup that was made from the a different cluster, (i.e. cluster migration via restore), please reference the Cluster Migration via Restore How-To:
- Scale-down to the single MySQL unit (scale it up after the backup is restored).
- Access to S3 storage
- Have configured settings for S3 storage
- Have existing backups in your S3-storage
- Point-in-time recovery requires the following MySQL charm revisions:
- 369+ for
arm64 - 368+ for
amd64
- 369+ for
List backups
To view the available backups to restore you can enter the command list-backups:
juju run mysql/leader list-backups
This should show your available backups
backups: |-
backup-id | backup-type | backup-status
YYYY-MM-DDTHH:MM:SSZ | physical | finished
Point-in-time recovery (PITR) is a MySQL feature that enables restorations to the database state at specific points in time. The feature is enabled by default when there’s a working relation with S3 storage.
Restore backup
To restore a backup from that list, run the restore command and pass the backup-id to restore:
juju run mysql/leader restore backup-id=YYYY-MM-DDTHH:MM:SSZ
Your restore will then be in progress.
However, if the user needs to restore to a specific point in time between different backups (e.g. to restore only specific transactions made between those backups), they can use the restore-to-time parameter to pass a timestamp related to the moment they want to restore.
juju run mysql/leader restore restore-to-time="YYYY-MM-DD HH:MM:SS"
It’s also possible to restore to the latest point from a specific timeline by passing the ID of a backup taken on that timeline and restore-to-time=latest when requesting a restore:
juju run mysql/leader restore restore-to-time=latest
