Charmed MongoDB Tutorials > Deploy a sharded cluster > 3. Access a sharded cluster
This page of the tutorial for deploying Charmed MongoDB K8s on sharded clusters is currently under construction.
In the meantime, to learn how to access a sharded cluster, you can follow the links provided in this page, or follow the sharded cluster tutorial for MongoDB on virtual machines
Thank you for your patience!
To deploy, integrate, and retrieve the URI, see: Mongos K8s documentation > Get started (external page)
To access the mongo
shell and create a test database, see Tutorial > Deploy a replica set > 3. Access a replica set
Keep in mind that for a sharded cluster, you must ssh
into the config-server
unit instead of mongodb-k8s
Next Step: 4. Add and remove shards
