Charmed MongoDB K8s Reference | Revision 61
Revision 61 release notes
21 October 2024
Charmed MongoDB K8s Revision 61 has been deployed to the 6/stable channel on Charmhub.
Highlights
This section goes over the features included in this release, starting with a description of major highlights, and finishing with a comprehensive list of all other features.
  • User Management
  • Sharding
  • Backups
  • Security with TLS
  • Accessibility outside of K8s with the mongos-k8s router
  • Metrics with COS integration - with all sharding components visible in the same dashboard
Other features
  • Audit logging
  • Log rotation
  • Integration to mongos
For a detailed list of commits throughout all revisions, check our GitHub Releases.
Requirements and compatibility
  • Juju v3.*
See the system requirements page for more information about software and hardware prerequisites.
Integrations
See the Integrations page for a list of all interfaces and compatible charms.
Software contents
This charm is based on the Canonical charmed mongodb rock. It packages:
  • Percona Server for MongoDB v6.0.6-5
  • MongoDB Exporter v0.40.0
  • mongosh 2.3.1
  • Percona Backup for MongoDB 2.4.0
Known issues and limitations
The following issues are known.
  • Restores on backups with old passwords will leave clients / operator user locked out of the DB
  • Removing a shard before breaking its integration with the config-server results in data loss
  • Sharding cluster cannot drain jumbo chunks - draining jumbo chunks requires manual intervention
Join the community
Charmed MongoDB is an open source project that warmly welcomes community contributions, suggestions, fixes, and constructive feedback.
