Charmed MongoDB K8s How to | Deploy MongoDB
How to deploy MongoDB K8s
This is a guide on how to deploy Charmed MongoDB K8s as a replica set or a sharded cluster.
Create a MongoDB replica set
You can create one or multiple replicas at once when deploying MongoDB K8s.
Deploy a single replica
To deploy a single unit of MongoDB as a replica set, run:
juju deploy mongodb-k8s --trust
The --trust flag is necessary to grant the application access to the Kubernetes cluster.
Deploy multiple replicas
To deploy MongoDB with multiple replicas, specify the number of desired replicas with the -n option:
juju deploy mongodb-k8s -n <number_of_replicas>
Create a MongoDB sharded cluster
To create a sharded cluster, we must first deploy each cluster component separately with a manually defined role, then integrate them.
Deploy cluster components with a single replica
Deploying a shard application will assign it one replica by default.
To deploy a sharded cluster with two shards, run:
juju deploy mongodb-k8s --config role="config-server" <config_server_name>
juju deploy mongodb-k8s --config role="shard" <shard_name_0>
juju deploy mongodb-k8s --config role="shard" <shard_name_1>
This will deploy the latest stable release . To specify a different version, use the --channel flag, e.g. --channel=6/beta.
Deploy cluster components with multiple replicas
To configure the amount of replicas for a shard or config-server during deployment, just use the -n flag.
To deploy a shard and config-server with 3 replicas each, run:
juju deploy mongodb-k8s --config role="shard" <shard_name> -n 3
juju deploy mongodb-k8s --config role="config-server" <config_server_name> -n 3
Note that you can also change the number of replicas for a shard or config server after deployment. See Scale replicas and shards > How to add shards to a cluster.
Integrate cluster components
To create a cluster, integrate the shard applications with the config-server application.
For the case of two shards and one config server, you would run:
juju integrate config-server:config-server <shard_name_0>:sharding
juju integrate config-server:config-server <shard_name_1>:sharding
Deploy with Terraform
Make sure you have a working Terraform 1.8+ installed in your machine. You can install Terraform or OpenTofu via a snap.
Terraform modules make use of the Terraform Juju provider. More information about the Juju provider can be found here. For more information about Terraform, please refer to the official docs.
Charmed MongoDB K8s has a base module that bundles all the base resources of the Charmed MongoDB K8s solution. But it also provides two product modules that bundle all the resources and integrations for replica set deployments and sharded deployments. These deployments also integrate with necessary applications for: backups (s3-integrator), client connections (data-integrator), encryption (self-signed-certificates), and in the case of a sharded cluster a mongos router.
Deploy a replica set with terraform
Get access to the replica set product terraform module code:
git clone https://github.com/canonical/mongodb-k8s-operator.git
cd terraform/modules/replica_set
Then deploy Charmed MongoDB K8s using the stand Terraform commands:
terraform init
terraform plan -out myfile
terraform apply "myfile"
Then you can watch and wait for your replica set to become available.
Deploy a sharded cluster with terraform
Get access to the shareded cluster product terraform module code:
cd terraform/modules/sharded_cluster
terraform init
Then you can watch and wait for your shareded cluster to become available.
