How to migrate to a new a cluster via restore
This page contains the steps needed to prepare for and perform a restore of a backup from a different cluster, i.e. cluster migration via restore.
We will use the following terms:
- new cluster - the backed-up cluster that we will migrate data from.
 - old cluster - the currently active cluster that will be restored to the state of the new cluster.
- For bare replica sets:
- The new cluster has a number of replicas equal to or greater than the old cluster.
- E.g. Your old cluster had 2 replicas, so your new cluster must have 2 or more replicas
 - See How To > Scale replicas and shards
 - For sharded clusters:
- The new cluster has a number of shards and replicas equal to or greater than those in the old cluster.
- E.g. Your old cluster had 2 shards, so your new cluster must have 2 or more shards.
 - E.g. Your old shard had 4 replicas, so your new shard must have 4 or more replicas.
 - Configured settings for S3 storage
 - Backups from the new cluster in your S3 storage
 - Password from your new cluster
- Change password of old cluster
 - List all backups
 - Define remap pattern (sharded cluster only)
 - Restore backup
The migration process will restore the password from the new cluster to your old cluster. Set the password of your old cluster to the new cluster’s password:
juju run <replica-set name | config-server name>/leader set-password password=<new cluster password>
List all backups
To view the available backups, enter the command list-backups:
juju run <replica-set name | config-server name>/leader list-backups
This shows a list of the available backups similar to the output below. Identify which backup-id corresponds to the new cluster.
    backup-id             | backup-type  | backup-status
    YYYY-MM-DDTHH:MM:SSZ  | logical      | finished
If you are running Charmed MongoDB K8s as a bare replica set, you can skip this step.A remap pattern is a pattern that specifies which old components should be migrated to which new components. They are used when we are migrating to a cluster with new names.
If you are running Charmed MongoDB K8s as a sharded cluster and you wish to migrate to a cluster with new names, you must generate a remap pattern.
The following example shows how to create a remap pattern for a sample cluster migration.
Sample old cluster:
Model    Controller  Cloud/Region         Version  SLA          Timestamp
old-mod  overlord    localhost/localhost  3.1.6    unsupported  17:27:22Z
App            Version  Status   Scale  Charm         Channel   Rev  Exposed  Message
application             active       1  application             0    no
config-server           active       1  mongodb-k8s   6/stable  158  no
shard-one               active       1  mongodb-k8s   6/stable  158  no
shard-two               active       1  mongodb-k8s   6/stable  158  no
Unit                         Workload  Agent   Address       Ports      Message
application/0*               active    idle    10.130.84.77
config-server/0*             active    idle    10.130.84.120
self-signed-certificates/0*  active    idle    10.130.84.32
shard-one/0*                 active    idle    10.130.84.78
shard-two/0*                 active    idle    10.130.84.68
Sample new cluster:
new-mod  overlord    localhost/localhost  3.1.6    unsupported  17:27:22Z
The following would be a valid remap pattern:
config-server-new=config-server,shard-one-new=shard-one,shard-two-new=shard-two
Restore backup
To restore your current cluster to the state of the previous cluster, run the restore command and pass the correct backup-id to the command:
juju run <replica-set name | config-server name>/leader restore backup-id=YYYY-MM-DDTHH:MM:SSZ [remap-pattern=<remap-pattern>]
Your restore will then be in progress. Once it is complete, your old cluster will represent the state of the new cluster.
