Charmed MongoDB K8s Explanation | Advanced Statuses
Advanced Statuses
MongoDB charms leverages Advanced Statuses to provide and expose detailed, component-specific status information. This interface supports more complex and multiple statuses.
Basics
Advanced Statuses are implemented in the homebrewed Data Platform Helpers library.
Each component of the charm recomputes its statuses on every status-update event, and will sort the statuses by order of importance.
They are first order like ops does: Error > Blocked > Maintenance > Waiting > Active > Unknown and then by component priority for an equal status level.
If multiple important (understand Blocked, Maintenance or Waiting) are reported, a special status is computed. This status has the priority of the most important status, and its message is the following:
"<status message>. Run `status-detail`: X action required; Y additional statuses")
For example, the following juju status output shows an aggregated status for a charmed-mongodb sharded deployment.
Model       Controller  Cloud/Region         Version  SLA          Timestamp
integ-test  overlord    localhost/localhost  3.6.8    unsupported  16:17:23+02:00
App                       Version  Status   Scale  Charm                     Channel        Rev  Exposed  Message
application                        active       1  application                                0  no
config-server             8.0.10   active       1  mongodb                                    0  no
config-server-two         8.0.10   active       1  mongodb                                    1  no
data-integrator                    blocked      1  data-integrator           latest/stable  180  no       Please specify either topic, index, database name, or prefix
mongos                             unknown      0  mongos                                     0  no
replication               8.0.10   active       1  mongodb                                    3  no
s3-integrator                      active       1  s3-integrator             latest/edge    192  no
self-signed-certificates           active       1  self-signed-certificates  latest/stable  264  no
shard-one                 8.0.10   active       1  mongodb                                    2  no
Unit                         Workload  Agent    Address         Ports   Message
application/0*               active    idle     10.137.178.161
config-server-two/0*         blocked   idle     10.137.178.124          Missing relation to shard(s).
config-server/0*             blocked   idle     10.137.178.103          Invalid database relation. Run `status-detail`: 1 action required; 2 additional statuses.
data-integrator/0*           blocked   idle     10.137.178.241          Please specify either topic, index, database name, or prefix
replication/0*               active    idle     10.137.178.242          Primary.
s3-integrator/0*             active    idle     10.137.178.92
self-signed-certificates/0*  active    idle     10.137.178.134
shard-one/0*                 blocked   idle     10.137.178.63           Missing relation to config-server.
Due to their extended structure, advanced statuses contain more information than regular ones, providing developers with valuable hints for operators. They can specify an action to run to resolve a status and indicate which check led to the status being computed.
Statuses can be set as critical so that they override the regular flow and are displayed no matter what happens if they require immediate action.
status-detail action
The status-detail action is a helper that provides extended access to the charm statuses.
Running this action will display all application and unit statuses. It includes an optional recompute argument that allows for status re-evaluation. When recompute is used, the system re-computes statuses for non-leader units and all statuses for leader units.
Note: Though the recompute flag will yield the most up-to-date status of the application, it can also come with a performance penalty depending on the list of deployed components.
This action is particularly useful for debugging and understanding the charm’s current state, as it provides a detailed view of all statuses, including those not visible in the standard status output.
Running the status-detail action produces output similar to the following (example run on a mongodb config-server unit, though we should expect a similarly formatted output when running this action against a mongodb-k8s unit):
juju run config-server/0 status-detail
Running operation 9 with 1 task
  - task 10 on unit-config-server-0
Waiting for task 10...
16:16:55 Stored statuses:
16:16:55                      App Statuses
| Status | Component Name | Message | Action | Reason |
| Active | upgrade        |         | N/A    | N/A    |
16:16:55                      Unit Statuses
| Blocked  | mongod         | The database       | Remove the       | Relation    |
|          |                | relation cannot    | database         | validation. |
|          |                | be used by         | relation         |             |
|          |                | sharding           | (mongodb_client  |             |
|          |                | components         | interface) from  |             |
|          |                | (shards or         | this application.|             |
|          |                | config servers).   |                  |             |
| Blocked  | backup         | s3 configurations  | N/A              | N/A         |
|          |                | missing.           |                  |             |
| Blocked  | backup         | s3 credentials are | Check S3         | N/A         |
|          |                | incorrect.         | credentials on   |             |
|          |                |                    | s3-integrator    |             |
| Active   | mongo          | Primary.           | N/A              | N/A         |
json-output:
  app: '[{"Status": "Active", "Component Name": "upgrade", "Message": "", "Action":
    "N/A", "Reason": "N/A"}]'
  unit: '[{"Status": "Blocked", "Component Name": "mongod", "Message": "The database
    relation cannot be used by sharding components (shards or config servers).", "Action":
    "Remove the database relation (mongodb_client interface) from this application.",
    "Reason": "Relation validation."}, {"Status": "Blocked", "Component Name": "backup",
    "Message": "s3 configurations missing.", "Action": "N/A", "Reason": "N/A"}, {"Status":
    "Blocked", "Component Name": "backup", "Message": "s3 credentials are incorrect.",
    "Action": "Check S3 credentials on s3-integrator", "Reason": "N/A"}, {"Status": "Active",
    "Component Name": "mongo",  "Message": "Primary.", "Action": "N/A", "Reason": "N/A"},
    {"Status": "Active", "Component Name": "upgrade", "Message": "", "Action": "N/A",
    "Reason": "N/A"}]'
This output provides a comprehensive view of statuses, detailing component names, messages, actions, and reasons for each status. The json-output section at the end offers a structured format, which is ideal for parsing by automation tools and scripts.
Developing with advanced statuses
With advanced statuses, the charm never sets statuses directly but goes through the Data Platform Helpers advanced statuses module.
While documentation is available in the library, keep these key points in mind:
  • Add new statuses to the status collection in src/statuses.py.
  • Ensure your manager inherits from the ManagerStatusProtocol.
  • Implement the get_statuses(scope, recompute) method within your manager.
  • Add your manager to the list of those that report statuses in src/charm.py.
