Set up Charm-Level Tracing
While developing and debugging, it can be helpful to see traces of the MAAS Site Manager charm’s workload. In this section, we will set up some necessary Juju components and relate them to MAAS Site Manager K8s in order to see these traces.
Note: You must have completed the last section if you would like to enable charm-level tracing.
Before beginning, ensure you are working in the cos-lite model by running:
juju switch cos-lite
Deploy Tempo K8s
First, deploy the Tempo Coordinator and Worker charms, and wait for them to report as blocked/idle:
juju deploy tempo-coordinator-k8s --channel edge --trust tempo
juju deploy tempo-worker-k8s --channel edge --trust tempo-worker
juju status --watch 5s
Next, integrate the coordinator and worker charms:
juju integrate tempo tempo-worker
Deploy Minio and S3
Next, create an access and secret key and store them as environment variables. The secret key must be at least 8 characters.
export ACCESS_KEY=accesskey
export SECRET_KEY=mysoverysecretkey
Next, deploy Minio with the access and secret key created above. Wait for it to report as active/idle.
juju deploy minio --channel edge --trust --config access-key=$ACCESS_KEY --config secret-key=$SECRET_KEY
Next, deploy S3 and wait for it to report as blocked/idle:
juju deploy s3-integrator --channel edge --trust s3
Once S3 is in a blocked/idle state, run the sync-s3-credentials action:
juju run s3/leader sync-s3-credentials access-key=$ACCESS_KEY secret-key=$SECRET_KEY
Create a Bucket in Minio
Next, we will create a bucket in Minio. First, store the IP address of the minio/0 unit (NOT the Minio application) reported by juju status in an environment variable:
juju status # Note the IP of the minio/0 unit
export MINIO_IP="10.1.64.154"
Then, we will run a short Python script to create the bucket. Before doing so, ensure you have installed the minio pip package:
pip install minio
Now, we can finally create our bucket with this Python script. Be sure to run this in the same terminal session where we created our environment variables earlier (ACCESS_KEY, SECRET_KEY, and MINIO_IP).
from minio import Minio
from os import getenv
address = getenv("MINIO_IP")
bucket_name = "tempo"
mc_client = Minio(
f"{address}:9000",
access_key=getenv("ACCESS_KEY"),
secret_key=getenv("SECRET_KEY"),
secure=False,
found = mc_client.bucket_exists(bucket_name)
if not found:
mc_client.make_bucket(bucket_name)
Next, we provide a configuration to S3 and some relations for the charms we deployed above:
juju config s3 endpoint=minio-0.minio-endpoints.cos-lite.svc.cluster.local:9000 bucket=tempo
juju integrate tempo s3
juju integrate tempo:ingress traefik
juju relate tempo:grafana-source grafana:grafana-source
Finally, relate MAAS Site Manager K8s with Tempo:
juju offer tempo:tracing
juju switch msm
juju integrate maas-site-manager-k8s admin/cos-lite.tempo
Charm-level tracing also requires a reverse-proxy service, which will be set up in the next section.
Next Step: Set up a reverse-proxy and log in
