Deploy Temporal
MAAS Site Manager uses Temporal Workflows for long-running tasks. Follow the steps below to deploy charmed Temporal.
Deploy Temporal Server
First, add another Juju model for Temporal and deploy the Temporal charms:
juju add-model temporal
juju deploy temporal-k8s --config num-history-shards=4
juju deploy temporal-admin-k8s
juju deploy temporal-ui-k8s --config external-hostname=temporal-ui
Next, create relations for the Temporal charms:
juju consume admin/msm.pgsql
juju relate temporal-k8s:db admin/msm.pgsql
juju relate temporal-k8s:visibility admin/msm.pgsql
juju relate temporal-k8s:admin temporal-admin-k8s:admin
juju relate temporal-k8s:ui temporal-ui-k8s:ui
Once the charms have settled and are active/idle, create a Temporal namespace for MAAS Site Manager. Here, we use the name msm-namespace:
juju run temporal-admin-k8s/0 tctl args="--ns msm-namespace namespace register -rd 3" --wait 1m
Deploy Ingress Controller
To enable TLS connections, you must have a TLS certificate stored as a k8s secret. You can create a self-signed certificate and store it in a secret as follows:
# Generate private key
openssl genrsa -out server.key 2048
# Generate a certificate signing request
openssl req -new -key server.key -out server.csr -subj "/CN=temporal"
# Create self-signed certificate
openssl x509 -req -days 365 -in server.csr -signkey server.key -out server.crt -extfile <(printf "subjectAltName=DNS:temporal")
# Create a k8s secret
microk8s kubectl -n temporal create secret tls temporal-tls --cert=server.crt --key=server.key
Repeat this process for the Temporal UI:
openssl req -new -key server.key -out server.csr -subj "/CN=temporal-ui"
openssl x509 -req -days 365 -in server.csr -signkey server.key -out server.crt -extfile <(printf "subjectAltName=DNS:temporal-ui")
microk8s kubectl -n temporal create secret tls temporal-ui-tls --cert=server.crt --key=server.key
Next, enable ingress and deploy two instances of nginx-ingress-integrator under the names ingress and ingress-ui and wait for them to enter an waiting/idle state:
sudo microk8s enable ingress
juju deploy nginx-ingress-integrator ingress --channel edge --trust --config service-hostname=temporal --config tls-secret-name=temporal-tls
juju deploy nginx-ingress-integrator ingress-ui --channel edge --trust --config service-hostname=temporal-ui --config tls-secret-name=temporal-ui-tls
juju status --watch 5s
Next, relate temporal-ui-k8s and temporal-k8s to the respective nginx-ingress-integrator applications:
juju relate temporal-k8s ingress
juju relate temporal-ui-k8s ingress-ui
Finally, configure the tls-secret-name for temporal-k8s and temporal-ui-k8s:
juju config temporal-k8s tls-secret-name=temporal-tls
juju config temporal-ui-k8s tls-secret-name=temporal-ui-tls
To verify that ingress resources were created correctly, run the following command:
microk8s kubectl describe ingress -n temporal
You should see an output similar to below, with differing IP addresses:
Labels: app.juju.is/created-by=nginx-ingress-integrator
nginx-ingress-integrator.charm.juju.is/managed-by=nginx-ingress-integrator
Namespace: temporal-model
Address: 127.0.0.1
Ingress Class: public
Default backend: <default>
TLS:
temporal-tls terminates temporal-k8s
Rules:
Host Path Backends
temporal-k8s
/ temporal-k8s-service:7233 (10.1.232.64:7233)
Annotations: nginx.ingress.kubernetes.io/backend-protocol: GRPC
nginx.ingress.kubernetes.io/proxy-body-size: 20m
nginx.ingress.kubernetes.io/proxy-read-timeout: 60
nginx.ingress.kubernetes.io/rewrite-target: /
Events: <none>
Address: 127.0.0.1
TLS:
temporal-tls terminates temporal-ui-k8s
Rules:
Host Path Backends
temporal-ui-k8s
/ temporal-ui-k8s-service:8080 (10.1.232.72:8080)
Annotations: nginx.ingress.kubernetes.io/backend-protocol: HTTP
Events: <none>
Note the IP address and port of the temporal-k8s service (in the output above, this is 10.1.232.64:7233).
Next Step: Set up a reverse-proxy
