Airbyte K8s Operator
This is the Kubernetes Python Operator for Airbyte.
Description
Airbyte is an open-source data integration platform designed to centralize and streamline the process of extracting and loading data from various sources into data warehouses, lakes, or other destinations.
This operator provides an Airbyte server, and consists of Python scripts which wraps the versions distributed by Airbyte.
Usage
Note: This operator requires the use of juju>=3.1.
The Airbyte charm relies on a number of other charms for core functionality.
Below is a set of requirements and the charms that fulfill them:
- Database: Postgresql-k8s
- Workflow Engine: Temporal-k8s
- Object Storage:
Note: For object storage, the use of one of the Minio or S3 integrator charm is sufficient.
Deploying PostgreSQL Database
Airbyte uses PostgreSQL for storing metadata. The Airbyte and PostgreSQL operators can be deployed and connected to each other using the Juju command line as follows:
juju deploy airbyte-k8s --channel edge --trust
juju deploy postgresql-k8s --channel 14/edge --trust
juju relate airbyte-k8s postgresql-k8s
Deploying Minio
Airbyte uses Minio for storing state and relevant logs. The Airbyte and Minio operators can be deployed and connected to each other using the Juju command line as follows:
juju deploy minio --channel edge
juju relate airbyte-k8s minio
Deploying Temporal
Airbyte uses Temporal as a workflow engine for durable execution of sync jobs. The Temporal operators can be deployed and connected to each other using the Juju command line as follows:
juju deploy temporal-k8s
juju deploy temporal-admin-k8s
juju relate temporal-k8s:db postgresql-k8s:database
juju relate temporal-k8s:visibility postgresql-k8s:database
juju relate temporal-k8s:admin temporal-admin-k8s:admin
Once the units have settled, the following command can be run to create the default namespace:
juju run temporal-admin-k8s/0 tctl args="--ns default namespace register -rd 3"
The Airbyte charm is configured by default to connect to the Temporal charm at
temporal-k8s:7233, so no further action is needed here.
Deploying Airbyte UI
To configure connectors through the web UI, the Airbyte operator requires integration with the Airbyte UI operator.
Once the Airbyte UI operator is deployed, it can be connected to the Airbyte operator using the Juju command line as follows:
juju deploy airbyte-ui-k8s
juju relate airbyte-k8s airbyte-ui-k8s
You should now be able to access the web UI at <airbyte_ui_unit_ip>:8080.
Verifying
To verify that the setup is running correctly, run juju status --relations --watch 2s and ensure that all pods are active and all required integrations exist.
Contributing
This charm is still in active development. Please see the Juju SDK docs for guidelines on enhancements to this charm following best practice guidelines, and CONTRIBUTING.md for developer guidance.
