Migration steps from the policy-routing charm
Initial deployment
The following steps assume that an ubuntu unit with a subordinate policy-routing charm with the following config has been deployed:
application: policy-routing
application-config:
trust:
default: false
description: Does this application have access to trusted credentials
source: default
type: bool
value: false
charm: policy-routing
settings:
cidr:
description: |
CIDR of the network interface to setup a policy routing.
e.g. 192.168.0.0/24
source: user
type: string
value: 10.10.51.0/24
gateway:
description: |
The gateway to be used from the network interface specified with
the CIDR. e.g. 192.168.0.254
source: user
type: string
value: 10.10.51.1
juju status looks like:
$ juju status
model1 lxd localhost/localhost 2.7.2 unsupported 11:52:19Z
policy-routing waiting 0 policy-routing jujucharms 3 ubuntu
ubuntu 18.04 active 1 ubuntu jujucharms 15 ubuntu
ubuntu/0* active idle 127 10.0.8.155 ready
policy-routing/0* active idle 10.0.8.155 Unit ready
Deploy advanced-routing charm
juju deploy advanced-routingjuju add-relation ubuntu advanced-routing
Advanced-routing is in status blocked with message: “Please disable charm-policy-routing”
Apply the following config:
$ cat ./advanced_routing_config
advanced-routing:
enable-advanced-routing: true
advanced-routing-config: |
"type": "table",
"table": "SF1"
"type": "route",
"default_route": true,
"gateway": "10.10.51.1",
"table": "SF1"
"type": "rule",
"from-net": "10.10.51.0/24",
"to-net": "10.10.51.0/24",
"priority": 100
"type": "rule",
"table": "SF1",
"priority": 101
with the command:
juju config advanced-routing --file ./advanced_routing_config
Disable the old config
juju run -u ubuntu/0 "sudo systemctl stop charm-pre-install-policy-routing ; sudo systemctl disable charm-pre-install-policy-routing ; sudo rm -f /etc/systemd/system/charm-pre-install-policy-routing.service; "
Apply the routing configuration with the new charm
Using the action apply-changes, add the routes using the advance-routing charm
juju run-action advanced-routing/0 apply-changes --wait
