Advanced Routing
This subordinate charm allows for the configuration of policy routing rules on the deployed host, as well as routes to configured services. A list of hash maps, in JSON format, is expected.
Charm supports IPv4 addressing.
Warning: if configured incorrectly, this has the potential to disrupt your units networking setup. Be sure to test your configuration before rolling it out to production. Note the charm provides an apply-changes action, which allows you to apply routing changes per unit as a way to mitigate risk
Security, Bugs and feature request
If you find a bug in this application or want to request a specific feature, here are the useful links:
Raise issues or feature requests on Github/Launchpad
Security issues in the charm-advanced-routing can be reported through LaunchPad. [Please do not file GitHub issues about security issues.]
Contributing
Please see the Juju SDK docs for guidelines on enhancements to this charm following best practice guidelines, and CONTRIBUTING.md for developer guidance.
License
The charm-advanced-routing is free software, distributed under the Apache Software License, version 2.0. See LICENSE for more information.
Navigation
| Level | Path | Navlink |
| 1 | Tutorial | Tutorial |
| 2 | t-getting-started | Getting Started |
| 1 | How to | How to |
| 2 | h-migrate-from-the-policy-routing-charm | Migrate from the policy-routing charm |
| 1 | Reference | Reference |
| 2 | r-actions | Actions |
| 2 | r-libraries | Libraries |
| 2 | r-resources | Resources |
| 2 | r-integrations | Integrations |
| 2 | r-configurations | Configurations |
| 1 | Explanation | Explanation |
| 2 | e-understanding-the-configuration-options | Understanding the configuration options |
