Charmcraft supports the development of operators using the Charmed Operator Framework. It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
This new version was just released to beta channel, I’d appreciate any tests on this, please report here any issues you find. In a couple of days I will release it to candidate, and once I find this is solid enough, I will release it to stable.
Beware! As it may be expected by a major version release, some backwards compatibility is broken; I just posted details about this, including instructions to stay away from this change and remain in the safe(old) versions…
Version 2.0.0 includes the following changes:
Started to use the new Craft CLI, which brings to the project better verbosity levels and improved verbosity-related global options
Added programmatic outputs to several commands (related issue)
Several deprecations were enforced:
- (DN03) The
baseskey in the configuration is now required (related issue) - (DN04) Removed the
--entrypointoption from thepackcommand (usecharm-entrypointin the config) (related issue) - (DN05) Removed the
--requirementsoption from thepackcommand (usecharm-requirementsin the config) (related issue) - (DN06) Removed the long time deprecated
buildcommand (usepackinstead)
- (DN03) The
Now the
--forceoption in thepackcommand is also used when packing inside an instance -
Do not expose the logpath (from the instance) when running in managed mode (related issue)
Validate the entrypoint after build (not before, as it may be created during the build itself) (related issue)
Do not modify the charm’s project when packing using the reactive plugin (related issue)
Use Charmcraft to:
- Pack your Charmed Operator into a charm for distribution
Happy charming!
