Abstract
Definition of some Charmcraft commands’ outputs that are easily consumable by other programs/scripts.
Rationale
Charmcraft is used more and more in automatic systems (e.g. CI/CD). To simplify the automation scripts, Charmcraft should be able to be used programmatically. This means that it should provide a simple way to parse its outputs.
Currently one command provides a way to format its output for easy programmatic consumption: analyze. It has a --format option that allows to specify in which format the output should be encoded (currently only JSON). If the option is not used, the output is formatted for easier human readability.
This proposal formalizes the extension of that mechanism to most Charmcraft commands.
Exceptions
Not all commands need to be consumed programmatically, though. Here is a list of those exceptions and the reasoning behind the exclusion.
help: its output is always intended for human consumption; furthermore, it’s automatically handled by Craft CLI, so we will not interfere from Charmcraft. -
loginandlogout: the login process always needs human interaction; logout is included here for symmetry. -
init: there is no information in the final output other than reminders for the developer on how to complete the provided template; if this command would be ever used programmatically, it would be enough to check the process’ return code. -
build: it’s deprecated.
Commands Without Outputs
The following are commands that even as they may be used programmatically, there is no information in the final output (just a message to the user that all ended correctly) so it’s enough to check the process’ return code.
cleancloseregisterregister-bundlerelease
Outputs Formats
The following would be the formats produced by the different commands.
Possible future changes in these formats should be specified including the Charmcraft version where they happened. Backwards incompatible changes should be minimized, and only be introduced in major Charmcraft versions.
pack:pkgtypemay be “charms” or “bundles”;nameNare the filenames of the produced binaries.
pkgtype: [name1, ...],
version:
"version": the_version_string,
whoami:name,usernameandidare optional, they will be present only ifloggedis True. Alsopermissions,channelandpackagesare optional keys, as those restrictions may not exist in the current credentials (the later may include charms/bundles or not). When charms or bundles are included, for each case it’s specified which type of identifier is used (nameorid) and its value.
"logged": bool,
"name": account_name, <-- optional
"username": account_username, <-- optional
"id": account_id, <-- optional
"permissions": [perm1, ...], <-- optional
"packages": <-- optional
"charms": [{identifier_type: identifier_value}, ...], <-- optional
"bundles": {identifier_type: identifier_value}, ...], <-- optional
"channels": [channel1, ...] <-- optional
names:
"name": name1,
"type": type1,
"visibility": visibility1,
"status": status1,
upload:errorsxorrevisionmay be present, according to success or not (which can also be verified using process’ return code)
"revision": uploaded_revision, <-- optional
"errors": [{"code": code1, "message": message1}, ...] <-- optional
revisions: if the status is notapprovedanerrorskey may be present with the relevant information.
"revision": revision1,
"version": version1,
"created_at": created_at1,
"status": status1,
"errors": [{"message": message1, "code": code1}, ...], # <-- optional
status:
"track": track_name,
"mappings": [
"base": # <--- this can be None (no dict with detailed info in that case)
"name": base_name,
"channel": channel,
"architecture": architecture,
"releases":
"status": status, # `open`, `tracking` or `closed`
"channel": channel,
"version": version,
"revision": revision,
"resources": [{"name": name1, "revision", ...],
"expires_at": timestamp_or_None,
create-lib:
"library_id": the_lib_id,
publish-lib:
"charm_name": charm_name1,
"library_name": lib_name1,
"library_id": lib_id1,
"api": api_version1,
"published": <-- optional
"patch": patch_version1,
"content_hash": hash1,
"error_message": explanation, <-- optional, and see note 1 below
fetch-lib:
"fetched": <-- optional
list-lib:
list-resources:
"charm_revision": charm_rev1,
"name": resource1,
"type": type1,
"optional": optional1,
upload-resource:errorsxorrevisionmay be present, according to success or not (which can also be verified using process’ return code)
list-resource-revisions
"created at": created_at1,
"size": size1,
Note 1: the error results for library related operations can be improved later if there is really need (having specific codes and extra metadata for the different errors); the current key is purposefully error_message so we could add a complex error in the future without breaking compatibility.
