So, I started a new fresh unit.
Copied back the complete /var/backup/pg
Created a new directory /var/backup/restore and fixed permissions…
Then I ran…
juju config postgresql wal_e_storage_uri="file://localhost/var/backups/restore"
… and then I tried the restore action…
erik@pixel:~ > juju run-action postgresql/4 wal-e-restore storage-uri="file://localhost/var/backups/pg" confirm=true --wait
unit-postgresql-4:
UnitId: postgresql/4
results:
Stderr: |
wal_e.main INFO MSG: starting WAL-E
DETAIL: The subcommand is "backup-list".
STRUCTURED: time=2022-01-26T20:07:32.659825-00 pid=44274
DETAIL: The subcommand is "backup-fetch".
STRUCTURED: time=2022-01-26T20:07:36.695406-00 pid=44393
wal_e.worker.file.file_worker INFO MSG: beginning partition download
DETAIL: The partition being downloaded is part_00000000.tar.lzo.
HINT: The absolute file key is var/backups/pg/basebackups_005/base_000000010000000000000006_00000040/tar_partitions/part_00000000.tar.lzo.
STRUCTURED: time=2022-01-26T20:07:36.936420-00 pid=44393
DETAIL: The subcommand is "delete everything".
STRUCTURED: time=2022-01-26T20:07:46.024054-00 pid=44430
wal_e.main INFO MSG: deleting data in the store
STRUCTURED: time=2022-01-26T20:07:46.156494-00 pid=44430
wal_e.worker.base INFO MSG: deleting part of wal logs
DETAIL: The key being deleted is file://localhost/var/backups/restore/wal_005/000000010000000000000001.lzo.
STRUCTURED: time=2022-01-26T20:07:46.164442-00 pid=44430
Job for postgresql@12-main.service failed because the service did not take the steps required by its unit configuration.
See "systemctl status postgresql@12-main.service" and "journalctl -xe" for details.
Stdout: |
lxc
pg_control version number: 1201
Catalog version number: 201909212
Database system identifier: 7057599724181653945
Database cluster state: in production
pg_control last modified: Wed Jan 26 19:43:28 2022
Latest checkpoint location: 0/6000060
Latest checkpoint's REDO location: 0/6000028
Latest checkpoint's REDO WAL file: 000000010000000000000006
Latest checkpoint's TimeLineID: 1
Latest checkpoint's PrevTimeLineID: 1
Latest checkpoint's full_page_writes: on
Latest checkpoint's NextXID: 0:488
Latest checkpoint's NextOID: 24576
Latest checkpoint's NextMultiXactId: 1
Latest checkpoint's NextMultiOffset: 0
Latest checkpoint's oldestXID: 479
Latest checkpoint's oldestXID's DB: 1
Latest checkpoint's oldestActiveXID: 488
Latest checkpoint's oldestMultiXid: 1
Latest checkpoint's oldestMulti's DB: 1
Latest checkpoint's oldestCommitTsXid:0
Latest checkpoint's newestCommitTsXid:0
Time of latest checkpoint: Wed Jan 26 19:43:28 2022
Fake LSN counter for unlogged rels: 0/3E8
Minimum recovery ending location: 0/0
Min recovery ending loc's timeline: 0
Backup start location: 0/0
Backup end location: 0/0
End-of-backup record required: no
wal_level setting: logical
wal_log_hints setting: off
max_connections setting: 100
max_worker_processes setting: 8
max_wal_senders setting: 10
max_prepared_xacts setting: 0
max_locks_per_xact setting: 64
track_commit_timestamp setting: off
Maximum data alignment: 8
Database block size: 8192
Blocks per segment of large relation: 131072
WAL block size: 8192
Bytes per WAL segment: 16777216
Maximum length of identifiers: 64
Maximum columns in an index: 32
Maximum size of a TOAST chunk: 1996
Size of a large-object chunk: 2048
Date/time type storage: 64-bit integers
Float4 argument passing: by value
Float8 argument passing: by value
Data page checksum version: 1
Mock authentication nonce: 540e679209ed9eca2d25eba22ac23d86a0485dff5a6b1bfa48c44d7985a86bd0
2022-01-26 19:53:44.292 GMT [31861] LOG: skipping missing configuration file "/etc/postgresql/12/main/juju_recovery.conf"
2022-01-26 19:53:44 UTC [31861]: [3-1] db=,user= LOG: starting PostgreSQL 12.9 (Ubuntu 12.9-0ubuntu0.20.04.1) on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, 64-bit
2022-01-26 19:53:44 UTC [31861]: [4-1] db=,user= LOG: listening on IPv4 address "0.0.0.0", port 5432
2022-01-26 19:53:44 UTC [31861]: [5-1] db=,user= LOG: listening on IPv6 address "::", port 5432
2022-01-26 19:53:44 UTC [31861]: [6-1] db=,user= LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2022-01-26 19:53:44 UTC [31862]: [1-1] db=,user= LOG: database system was shut down at 2022-01-26 19:53:37 UTC
2022-01-26 19:53:44 UTC [31861]: [7-1] db=,user= LOG: database system is ready to accept connections
2022-01-26 19:53:45 UTC [31870]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 19:53:45 UTC [31873]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 19:53:45 UTC [31873]: [2-1] db=template1,user=postgres LOG: connection authorized: user=postgres database=template1 application_name=psql
2022-01-26 19:53:45 UTC [31873]: [3-1] db=template1,user=postgres LOG: disconnection: session time: 0:00:00.014 user=postgres database=template1 host=[local]
2022-01-26 19:53:46 UTC [31876]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 19:53:46 UTC [31876]: [2-1] db=template1,user=postgres LOG: connection authorized: user=postgres database=template1 application_name=psql
2022-01-26 19:53:46 UTC [31876]: [3-1] db=template1,user=postgres LOG: disconnection: session time: 0:00:00.005 user=postgres database=template1 host=[local]
2022-01-26 19:53:46 UTC [31879]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 19:53:46 UTC [31879]: [2-1] db=template1,user=postgres LOG: connection authorized: user=postgres database=template1 application_name=psql
2022-01-26 19:53:46 UTC [31879]: [3-1] db=template1,user=postgres LOG: disconnection: session time: 0:00:00.005 user=postgres database=template1 host=[local]
2022-01-26 19:53:46 UTC [31880]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 19:53:46 UTC [31880]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 19:53:46 UTC [31880]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.008 user=postgres database=postgres host=[local]
2022-01-26 19:53:46 UTC [31901]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 19:53:46 UTC [31901]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 19:53:46 UTC [31901]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.107 user=postgres database=postgres host=[local]
2022-01-26 19:54:01 UTC [33301]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 19:54:01 UTC [33301]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 19:54:01 UTC [33301]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.007 user=postgres database=postgres host=[local]
2022-01-26 19:55:01 UTC [35594]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 19:55:01 UTC [35594]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 19:55:01 UTC [35594]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.009 user=postgres database=postgres host=[local]
2022-01-26 19:56:02 UTC [36998]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 19:56:02 UTC [36998]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 19:56:02 UTC [36998]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.010 user=postgres database=postgres host=[local]
2022-01-26 19:57:01 UTC [37017]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 19:57:01 UTC [37017]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 19:57:01 UTC [37017]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.008 user=postgres database=postgres host=[local]
2022-01-26 19:58:01 UTC [37136]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 19:58:01 UTC [37136]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 19:58:01 UTC [37136]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.007 user=postgres database=postgres host=[local]
2022-01-26 19:58:44 UTC [31863]: [1-1] db=,user= LOG: checkpoint starting: time
2022-01-26 19:58:45 UTC [31863]: [2-1] db=,user= LOG: checkpoint complete: wrote 4 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.434 s, sync=0.026 s, total=0.495 s; sync files=4, longest=0.007 s, average=0.007 s; distance=2 kB, estimate=2 kB
2022-01-26 19:59:01 UTC [37244]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 19:59:01 UTC [37244]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 19:59:01 UTC [37244]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.008 user=postgres database=postgres host=[local]
2022-01-26 20:00:01 UTC [37292]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 20:00:01 UTC [37292]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 20:00:01 UTC [37292]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.007 user=postgres database=postgres host=[local]
2022-01-26 20:01:01 UTC [38825]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 20:01:01 UTC [38825]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 20:01:01 UTC [38825]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.010 user=postgres database=postgres host=[local]
2022-01-26 20:02:01 UTC [38844]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 20:02:01 UTC [38844]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 20:02:01 UTC [38844]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.008 user=postgres database=postgres host=[local]
2022-01-26 20:03:01 UTC [38864]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 20:03:01 UTC [38864]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 20:03:01 UTC [38864]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.008 user=postgres database=postgres host=[local]
2022-01-26 20:04:02 UTC [39562]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 20:04:02 UTC [39562]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 20:04:02 UTC [39562]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.009 user=postgres database=postgres host=[local]
2022-01-26 20:05:01 UTC [41654]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 20:05:01 UTC [41654]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 20:05:01 UTC [41654]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.008 user=postgres database=postgres host=[local]
2022-01-26 20:06:01 UTC [41680]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 20:06:01 UTC [41680]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 20:06:01 UTC [41680]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.011 user=postgres database=postgres host=[local]
2022-01-26 20:07:01 UTC [43092]: [1-1] db=[unknown],user=[unknown] LOG: connection received: host=[local]
2022-01-26 20:07:01 UTC [43092]: [2-1] db=postgres,user=postgres LOG: connection authorized: user=postgres database=postgres
2022-01-26 20:07:01 UTC [43092]: [3-1] db=postgres,user=postgres LOG: disconnection: session time: 0:00:00.009 user=postgres database=postgres host=[local]
2022-01-26 20:07:33 UTC [31861]: [8-1] db=,user= LOG: received fast shutdown request
2022-01-26 20:07:33 UTC [31861]: [9-1] db=,user= LOG: aborting any active transactions
2022-01-26 20:07:33 UTC [31861]: [10-1] db=,user= LOG: background worker "logical replication launcher" (PID 31869) exited with exit code 1
2022-01-26 20:07:33 UTC [31863]: [3-1] db=,user= LOG: shutting down
2022-01-26 20:07:33 UTC [31863]: [4-1] db=,user= LOG: checkpoint starting: shutdown immediate
2022-01-26 20:07:33 UTC [31863]: [5-1] db=,user= LOG: checkpoint complete: wrote 0 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.024 s, sync=0.001 s, total=0.260 s; sync files=0, longest=0.000 s, average=0.000 s; distance=7754 kB, estimate=7754 kB
2022-01-26 20:07:34 UTC [31861]: [11-1] db=,user= LOG: database system is shut down
2022-01-26 20:07:46.422 GMT [44471] LOG: skipping missing configuration file "/etc/postgresql/12/main/juju_recovery.conf"
2022-01-26 20:07:46 UTC [44471]: [3-1] db=,user= LOG: starting PostgreSQL 12.9 (Ubuntu 12.9-0ubuntu0.20.04.1) on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, 64-bit
2022-01-26 20:07:46 UTC [44471]: [4-1] db=,user= LOG: listening on IPv4 address "0.0.0.0", port 5432
2022-01-26 20:07:46 UTC [44471]: [5-1] db=,user= LOG: listening on IPv6 address "::", port 5432
2022-01-26 20:07:46 UTC [44471]: [6-1] db=,user= LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2022-01-26 20:07:46 UTC [44473]: [1-1] db=,user= LOG: database system was interrupted; last known up at 2022-01-26 19:43:28 UTC
2022-01-26 20:07:46 UTC [44473]: [2-1] db=,user= LOG: creating missing WAL directory "pg_wal/archive_status"
2022-01-26 20:07:46 UTC [44473]: [3-1] db=,user= FATAL: using recovery command file "recovery.conf" is not supported
2022-01-26 20:07:46 UTC [44471]: [7-1] db=,user= LOG: startup process (PID 44473) exited with exit code 1
2022-01-26 20:07:46 UTC [44471]: [8-1] db=,user= LOG: aborting startup due to startup process failure
2022-01-26 20:07:46 UTC [44471]: [9-1] db=,user= LOG: database system is shut down
pg_ctl: could not start server
Examine the log output.
recovery.conf exists at /var/lib/postgresql/12/main/recovery.conf
status: completed
timing:
completed: 2022-01-26 20:07:47 +0000 UTC
enqueued: 2022-01-26 20:07:29 +0000 UTC
started: 2022-01-26 20:07:29 +0000 UTC
… and my unit isn’t so happy.
