Deploying
$ juju add-model myzookeeper
$ juju deploy zookeeper-k8s -n 3
Where:
zookeeper-k8s: the name of this Charmed Operator on the Charmhub. -
-n: the number of Juju units to deploy, i.e. the number of wanted k8s pods. Any number>= 1is supported but for production you should pick an odd number>= 3.
Inspecting/Operating
The deployment can be inspected with juju and kubectl:
$ juju status
myzookeeper micro microk8s/localhost 2.9.0 unsupported 12:27:29Z
App Version Status Scale Charm Store Channel Rev OS Address Message
zookeeper-k8s active 3 zookeeper-k8s charmhub stable 4 kubernetes
zookeeper-k8s/0 active idle 10.1.0.47
zookeeper-k8s/1* active idle 10.1.0.49
zookeeper-k8s/2 active idle 10.1.0.48
$ juju config zookeeper-k8s client-port
2181
$ kubectl get pods --namespace=myzookeeper
NAME READY STATUS RESTARTS AGE
modeloperator-75988dd959-vvh2t 1/1 Running 0 4m33s
zookeeper-k8s-2 2/2 Running 0 92s
zookeeper-k8s-1 2/2 Running 0 92s
zookeeper-k8s-0 2/2 Running 0 92s
This teaches us the IP addresses (here 10.1.0.47-49) and the TCP port (2181) to be used in order to access the ZooKeeper data from any client.
ZooKeeper can be seeded with some dummy data:
$ juju run-action zookeeper-k8s/0 seed-data --wait
This data should then be replicated accross the entire ZooKeeper cluster and all units should present that same data:
$ juju run-action zookeeper-k8s/0 zookeeper-k8s/1 zookeeper-k8s/2 dump-data --wait
unit-zookeeper-k8s-0:
UnitId: zookeeper-k8s/0
results:
content: '{''test-seed'': {''my-first-key'': b''my first value'', ''my-second-key'':
b''my second value''}, ''zookeeper'': {''config'': b''server.1=10.1.0.47:2888:3888:participant\nserver.2=10.1.0.48:2888:3888:participant\nserver.3=10.1.0.49:2888:3888:participant\nversion=0'',
''quota'': b''''}}'
status: completed
timing:
completed: 2021-06-02 11:41:36 +0000 UTC
enqueued: 2021-06-02 11:41:33 +0000 UTC
started: 2021-06-02 11:41:35 +0000 UTC
unit-zookeeper-k8s-1:
UnitId: zookeeper-k8s/1
results:
''quota'': b''''}}'
status: completed
timing:
unit-zookeeper-k8s-2:
UnitId: zookeeper-k8s/2
results:
''quota'': b''''}}'
status: completed
timing:
Any ZooKeeper client can be used to read and write data to/from the deployed ZooKeeper cluster, e.g. ZooNavigator:
$ sudo snap install zoonavigator # ZooNavigator's Web-UI is then served at:
$ firefox http://localhost:9000
Relating
Other Charmed Operators can be related to this one if they require a ZooKeeper database. The zookeeper-dummy-client-k8s is an example:
$ juju deploy zookeeper-dummy-client-k8s
$ juju add-relation zookeeper-k8s:client zookeeper-dummy-client-k8s:zookeeper
