How to upgrade
Before updating the charm you need to back up the database using
the MySQL charm’s create-backup action.
juju run mysql/leader create-backup
Additional information can be found about backing up in the MySQL documentation.
Then you can upgrade the WordPress charm:
juju refresh wordpress-k8s
After upgrading the WordPress charm you need to update the database schema:
juju run wordpress-k8s/0 update-database
