Wordpress Documentation OCI Image
OCI Image
wordpress-image
The wordpress-image is custom built to include a default set of plugins and themes. The list of plugins and themes can be found at the reference section of the documentation. Since WordPress is an application running on php, required libraries and dependencies are installed during the build process.
WordPress application installation is done at runtime during database connection setup. This can happen during database relation changed, database relation joined or database config changed events. To facilitate the WordPress installation process, WordPress CLI is embedded in the OCI image during the build step. The latest CLI php archive file from source is used.
Currently, WordPress version 5.9.3 is used alongside Ubuntu 20.04 base image. The Ubuntu base image hasn’t yet been upgraded to 22.04 due to an unsupported php version 8 for wordpress-launchpad-integration plugin (supported php version 7). All other plugins and themes use the latest stable version by default, downloaded from the source.
