How to install themes
Start by locating the theme from the WordPress themes page. Once you’ve located the theme, the
theme slug is the name of the theme from the URL of the selected theme page. For example, for
https://wordpress.org/themes/twentytwentytwo/ the plugin slug is “twentytwentytwo” after the
/themes/ path in the URL.
You can now install the theme using the theme slug with juju config:
juju config wordpress-k8s themes=<theme-slug>
To install multiple themes at once, append more themes separated by a comma.
juju config wordpress-k8s themes=<theme-slug>,<theme-slug>
Once the configuration is complete, you can navigate to http://<wordpress-unit-ip>/wp-admin/themes.php to
verify your new theme installation.
