How to install plugins
Start by locating the plugin from the WordPress plugins page.
Once you’ve located the plugin, the plugin slug is the name of the plugin from the URL of the
selected theme page. For example, for https://wordpress.org/plugins/akismet/ the plugin slug is
“akismet” after the “/plugins/” path in the URL.
You can now install the plugin using the plugin slug with juju config:
juju config wordpress-k8s plugins=<plugin-slug>
To install multiple plugins at once, append more plugins separated by a comma.
juju config wordpress-k8s plugins=<plugin-slug>,<plugin-slug>
Once the configuration is complete, you can navigate to http://<wordpress-unit-ip>/wp-admin/plugins.php to
verify your new plugin installation.
