How to retrieve initial credentials
Run the following command to get the initial admin password that can be used to login at
http://<wordpress-unit-ip>/wp-login.php.
juju run wordpress-k8s/0 get-initial-password
The output of the action should look something similar to the following:
unit-wordpress-k8s-0:
UnitId: wordpress-k8s/0
results:
password: <password>
status: completed
The password should look something like: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.
You can use the password to log in to the admin account in http://<wordpress-unit-ip>/wp-admin.php.
If the admin_password value was passed in the initial_settings configuration, the
password from this action is invalid.
