Wordpress Documentation Getting Started
Deploy the WordPress charm for the first time
The wordpress-k8s charm helps deploy a horizontally scalable WordPress application. This tutorial will walk you through each step to achieve a basic WordPress deployment.
What you’ll need
  • A working station, e.g., a laptop, with AMD64 architecture.
  • Juju 3 installed. For more information about how to install Juju, see Get started with Juju.
  • Juju bootstrapped to a MicroK8s controller: juju bootstrap microk8s tutorial-controller
You can get a working setup by using a Multipass VM as outlined in the Set up your test environment guide.
What you’ll do
  1. Deploy the WordPress K8s charm
  2. Deploy and integrate a database
  3. Get admin credentials
  4. Access the WordPress instance
  5. Clean up the environment
Set up the environment
To be able to work inside the Multipass VM, log in with the following command:
multipass shell my-juju-vm
If you’re working locally, you don’t need to do this step.
To manage resources effectively and to separate this tutorial’s workload from your usual work, create a new model in the MicroK8s controller using the following command:
juju add-model wordpress-tutorial
Start off by deploying the WordPress charm. By default it will deploy the latest stable release of the wordpress-k8s charm.
juju deploy wordpress-k8s
Deploy and integrate database
Deployment of WordPress requires a relational database. The integration with the mysql interface is required by the wordpress-k8s charm and hence, mysql-k8s charm will be used.
The following commands deploy the mysql-k8s charm and integrate it with the wordpress-k8s charm.
juju deploy mysql-k8s --trust
juju integrate wordpress-k8s mysql-k8s:database
The database interface is required since mysql-k8s charm provides multiple compatible interfaces.
Run juju status to see the current status of the deployment. The output should be similar to the following:
Model               Controller          Cloud/Region        Version  SLA          Timestamp
wordpress-tutorial  microk8s-localhost  microk8s/localhost  3.5.3    unsupported  18:48:09Z
App            Version                  Status  Scale  Charm          Channel        Rev  Address         Exposed  Message
mysql-k8s      8.0.37-0ubuntu0.22.04.3  active      1  mysql-k8s      8.0/stable     180  10.152.183.254  no
wordpress-k8s  6.4.3                    active      1  wordpress-k8s  latest/stable   87  10.152.183.56   no
Unit              Workload  Agent  Address       Ports  Message
mysql-k8s/0*      active    idle   10.1.200.163         Primary
wordpress-k8s/0*  active    idle   10.1.200.161
The deployment finishes when the status shows “Active” for both the WordPress and MySQL charms.
Now that we have an active deployment, let’s access the WordPress application by accessing the IP of a wordpress-k8s unit. To start managing WordPress as an administrator, you need to get the credentials for the admin account.
By running the get-initial-password action on a wordpress-k8s unit, Juju will read and fetch the admin credentials setup for you. You can use the following command below.
juju run wordpress-k8s/0 get-initial-password
The result should look something similar to the contents below:
  - task 2 on unit-wordpress-k8s-0
Waiting for task 2...
password: <password>
Password should look something like: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.
If you are using Multipass VM for this tutorial, you will need to route the IP from Multipass. To do this first get the IP of the Multipass VM. Outside the Multipass VM run:
multipass info my-juju-vm
The IP you see here will be called <VM_IP> in this example.
Then route:
sudo ip route add <UNIT_IP> via <VM_IP>
You can now access your WordPress application at http://<UNIT_IP>/wp-login.php and log in with the admin username and password from the previous action.
Congratulations! You have successfully deployed the WordPress charm, added a database, and accessed the application.
You can clean up your environment by following this guide: Tear down your test environment
Next steps
You achieved a basic deployment of the WordPress charm. If you want to go farther in your deployment or learn more about the charm, check out these pages:
Please replace the channel version to 8.0/stable. The track latest has been closed for charm mysql-k8s. Tnx!
This has been updated. Thanks for the feedback.
