Wordpress Documentation Enable Antispam (Akismet)
How to enable antispam (Akismet)
Obtain an API key for Akismet by visiting the Askimet official webpage and following the instructions.
Using your key, enable the Akismet plugin with:
juju config wordpress-k8s wp_plugin_akismet_key=<akismet-api-key>
The Akismet plugin should automatically be active after running the configuration.
