How to integrate with COS
Integrate with Prometheus K8s operator
Deploy and relate prometheus-k8s charm with wordpress-k8s
charm through the metrics-endpoint relation via prometheus_scrape interface. Prometheus should
start scraping the metrics exposed at :9117/metrics endpoint.
juju deploy prometheus-k8s
juju integrate wordpress-k8s prometheus-k8s
Integrate with Loki K8s operator
Deploy and relate loki-k8s charm with wordpress-k8s charm through
the logging relation via loki_push_api interface. Promtail worker should spawn and start pushing
Apache access logs and error logs to Loki.
juju deploy loki-k8s
juju integrate wordpress-k8s loki-k8s
Integrate with Grafana K8s operator
In order for the Grafana dashboard to function properly, Grafana should be able to connect to
Prometheus and Loki as its datasource. Deploy and relate the prometheus-k8s and loki-k8s
charms with grafana-k8s charm through the grafana-source integration.
Note that the integration grafana-source has to be explicitly stated since prometheus-k8s and
grafana-k8s share multiple interfaces.
juju deploy grafana-k8s
juju integrate prometheus-k8s:grafana-source grafana-k8s:grafana-source
juju integrate loki-k8s:grafana-source grafana-k8s:grafana-source
Then, the wordpress-k8s charm can be related with Grafana using the grafana-dashboard relation with
grafana_dashboard interface.
juju integrate wordpress-k8s grafana-k8s
To access the Grafana dashboard for the WordPress charm, run the get-admin-password action
to obtain credentials for admin access.
juju run grafana-k8s/0 get-admin-password
Log into the Grafana dashboard by visiting http://<grafana-unit-ip>:3000. Navigate to
http://<grafana-unit-ip>:3000/dashboards and access the WordPress dashboard named Wordpress Operator
Overview.
