Charm architecture
The wordpress-k8s charm aims to provide core functionalities of WordPress with horizontally scalable architecture, leveraging its flexible capabilities enhanced by plugins. Operational capabilities are enhanced through integration with the Canonical Observability Stack (COS) charms.
Containers
The core component of wordpress-k8s charm consists of a wordpress-k8s main workload container with an Apache Prometheus exporter. The services inside the container are driven by Pebble, a lightweight API-driven process supervisor that controls the lifecycle of a service. Learn more about Pebble and its layer configurations in the Pebble documentation.
C4Context
title Component diagram for Wordpress Charm
Container_Boundary(wordpress, "WordPress") {
Component(apache-server, "Apache server", "", "Serves the WordPress application")
Component(pebble, "Pebble", "", "Starts the WordPress server and app")
Rel(pebble, apache-server, "")
Container_Boundary(charm, "WordPress Operator") {
Component(charm, "WordPress Operator", "", "WordPress Operator (charm)")
Rel(pebble, charm, "")
WordPress
This container runs the main workload of the charm. The OCI image is custom built and includes
the WordPress CLI, Apache server and default WordPress plugins and themes. By
default, Apache server accepts all the web traffic on port 80 and redirects the requests to
WordPress PHP index file, handled by the default x-httpd-php handler. The configuration of the
Apache server redirects can be found in
wordpress_rock/files/etc/apache2
folder.
WordPress, by default, stores uploaded content files locally at /wp-content/uploads directory.
To make the content accessible across WordPress replication servers, a swift-proxy is added to
enable content storage on OpenStack Swift through the use of
wp_plugin_openstack-objectstorage_config configuration parameter. Swift proxy settings can be found
in docker-php-swift-proxy.conf
in the repository. The settings are dynamically modified during runtime when the
wp_plugin_openstack-objectstorage_config parameter is configured.
In order to enable monitoring of Apache server status, redirection to WordPress PHP for route
/server-status is overridden in
apache2.conf.
/server-status endpoint is accessed by apache-exporter service to convert and re-expose with
open metrics compliant format for integration with prometheus_scrape interface.
When a logging relation is joined, a promtail application is started via Pebble which starts
pushing Apache server logs to Loki. The configurations for Apache have been set up to stream logs
to both access.log, error.log files and container logs in
000-default.conf.
These files are essential for promtail to read and push latest logs to Loki periodically.
charm
This container is the main point of contact with the Juju controller. It communicates with Juju to
run necessary charm code defined by the main src/charm.py. The source code is copied to the
/var/lib/juju/agents/unit-UNIT_NAME/charm directory.
OCI image
The wordpress-image is custom built to include a default set of plugins and themes. The list of plugins and themes can be found at the reference section of the documentation. Since WordPress is an application running on PHP, required libraries and dependencies are installed during the build process.
WordPress application installation is done at runtime during database connection setup. This can happen during database relation changed, database relation joined or database config changed events. To facilitate the WordPress installation process, WordPress CLI is embedded in the OCI image during the build step. The latest CLI PHP archive file from source is used.
Currently, WordPress version 6.4.3 is used alongside Ubuntu 20.04 base image. The Ubuntu base image
hasn’t yet been upgraded to 22.04 due to an unsupported PHP version 8 for
wordpress-launchpad-integration plugin (which currently supports PHP version 7). All other plugins and themes use
the latest stable version by default, downloaded from the source.
Integrations
See Relation endpoints.
Peer relations
When deploying multiple replications of the wordpress-k8s charm, peer relations are set up to
ensure synchronization of data among replications. Namely, secrets and admin credentials are shared
among peers. See more about the secrets in the rotate-wordpress-secrets action in the
Actions tab.
Juju events
Juju events allow progression of the charm in its lifecycle and encapsulates part of the execution
context of a charm. Below is the list of observed events for wordpress-k8s charm with how the charm
reacts to the event. For more information about the charm’s lifecycle in general, refer to the
charm’s life documentation.
start
This event marks the charm’s state as started. The charm’s running state must be persisted by the charm in its own state. See the documentation on the start event.
uploads_storage_attached
This event marks the charm’s storage availability. The name of the event derived from the name of
the storage noted in the metadata.yaml configuration under “storage” key.
containers.wordpress.mounts.storage and storage.uploads section. The storage filesystem maps to
/var/www/html/wp-content/uploads directory of the WordPress application, which is used to store
uploaded content from the WordPress user.
leader_elected
This event is fired when Juju elects a leader unit among the replica peers. The wordpress-k8s charm then responds by setting up secrets and sharing them with peers through peer relation databag if not already set.
config-changed
The wordPress-k8s charm reacts to any configuration change and runs reconciliation between the current state and the desired state. See the list of configurations.
wordpress_pebble_ready
When this event is fired, wordpress-k8s charm installs, configures and starts Apache server for
WordPress through Pebble if the storage is available. Configurations that are set dynamically
include database connection and secrets used by the WordPress application. Dynamic configurations
are modified in wp-config.php file and the changes are pushed through Pebble.
apache_prometheus_exporter_pebble_ready
This event signals that the apache_prometheus_exporter container is ready in the pod. Apache
Prometheus exporter service is then started through Pebble.
wordpress-replica_relation_changed
When any of the relation is changed, wordpress-k8s charm must run reconciliation between the current state and the desired state with new relation data to synchronize the replication instances. The reconciliation process is divided into 3 distinct steps: core, theme and plugin reconciliation. Core reconciliation sets up the necessary WordPress application configuration: secrets and database connection. Theme and Plugin respectively reconcile between currently installed themes and plugins with the incoming list of themes and plugins.
upgrade-charm
The upgrade-charm event is fired on the upgrade charm command juju refresh wordpress-k8s. The command sets up
secrets in peer-relation databag for upgraded deployment of WordPress if it was not already set.
Charm code overview
The src/charm.py is the default entry point for a charm and has the WordpressCharm Python class which inherits from CharmBase.
CharmBase is the base class from which all Charms are formed, defined by Ops (Python framework for developing charms).
See more in the Juju docs: Charm.
The __init__ method guarantees that the charm observes all events relevant to its operation and handles them.
