WordPress Changlog
Changelog
All notable changes to this project will be documented in this file.
The format is based on Keep a Changelog.
Each revision is versioned by the date of the revision.
2025-09-16
  • docs: Update tutorial based on user feedback.
2025-07-02
  • docs: Update README and tutorial based on user feedback.
2025-05-29
  • docs: Fix issues found with local audit for style guide checks.
2025-03-11
  • fix: use supported YoastSEO plugin version.
  • docs: fix charm architecture diagram (separate charm containers boundary)
2025-03-10
  • Add charm architecture diagram.
  • Add changelog for tracking user-relevant changes.
