NOTE
This is a template to be copied/pasted and updated as required. Any changes to this template should be updated in the associated draft release notes for future releases.
To copy + paste the raw Markdown (which is what you want), click the edit button at the bottom of the page.
Section-specific instructions are provided as HTML comments in-line.
The Juju team is proud to release Juju 2.X.Y!
Major Feature #1
More and more about this feature with examples, links to the documentation discourse posts for this feature, etc.
Major Feature #2
This release includes more important fixes
How do I install Juju?
Other packages are available for a variety of platforms, including Windows and macOS. Refer to the full Juju installation documentation.
Those subscribed to a snap channel should be automatically upgraded. If you’re using the PPA or Homebrew for macOS, you should see an upgrade available.
How do I upgrade?
Upgrading Juju is a multi-step process:
- upgrade the client (the Juju binary that you interact with on the command-line)
- (recommended) verify that the client upgrade was successful
- (recommended) back up the controller
- upgrade the controller
- upgrade models
Upgrade the client
If you’ve installed Juju via the snap, your Juju will automatically be installed overnight. To force the update, run:
snap refresh juju
If you’re using the PPA:
sudo apt update
sudo apt upgrade
On Homebrew for macOS:
brew update
brew upgrade
Check version
To prevent any confusion in later steps, ensure that you’re using the new Juju version.
juju version
Check your $PATH environment variable and that you’ve installed the new version correctly.
On Linux and macOS, use the env command to inspect the environment. On MS Windows, use SET.
Backing up
juju create-backup
Upgrading controllers
Juju includes a command that instructs the controller to upgrade itself to the latest version.
juju upgrade-controller
How to upgrade the controller
First, check that you’re interacting with the intended controller. The juju models command reports the current controller on the first line.
juju models
To verify what will occur, use the --dry-run option.
When you’re happy, omit the flag:
Upgrade models
Your models remain at the same version until you have explicitly told Juju to upgrade them.
juju upgrade-model
How to upgrade your model(s)
Check that you’re operating in the correct model. juju model highlights the current model with an asterisk:
juju models
juju upgrade-juju --dry-run
juju upgrade-juju
Further instructions
Juju’s documentation pages provide detailed information about the upgrade process:
- https://discourse.jujucharms.com/t/controller-backups/1106
- https://discourse.jujucharms.com/t/upgrading-models/1154
- https://discourse.jujucharms.com/t/notes-on-upgrading-juju-software/1153
- https://discourse.jujucharms.com/t/troubleshooting-model-upgrades/1186
Feedback Appreciated!
We encourage everyone to let us know how you’re using Juju. Please ask questions on on Discourse, send us a message to our Twitter account @juju_devops, tweet using the hashtag #juju_devops, and chat with us at #juju on Freenode.
