NOTE: this is a template to be copied/pasted and updated as required. Any changes to this template should be updated in the associated draft release notes for the next releases.
The Juju team is proud to release Juju 2.X!
<–release summary with notes about major goals of the release and how some of the below features fit into a general theme–>
Major Feature #1
More and more about this feature with examples, links to the documentation discourse posts for this feature, etc.
Major Feature #2
This release includes more important fixes
<-- note that below the format is that each bullet point starts with a Bug ## that is a link to the bug in question followed by the title/summary information -->
How do I get it?
The best way to get your hands on this release of Juju is to install it as a
snap package
Other packages are available for a variety of platforms. Please see the online documentation at https://jujucharms.com/docs/stable/reference-install. Those subscribed to a snap channel should be automatically upgraded. If you’re using the ppa or homebrew, you should see an upgrade available.
Feedback Appreciated!
We encourage everyone to let us know how you’re using Juju. Join us on Discourse at https://discourse.jujucharms.com/, send us a message on Twitter using the hashtag #jujucharms, and join us at #juju on freenode.
