Users need to be able to roll changes to applications in a safe guided processes that controls the flow such that not all units of an HA application are hit at once. This also allows some manual canary testing and provides control over the flow of changes out to the model.
We propose to allow operators to manage this using model generations.
What is a model generation?
A model generation can refer to the current generation (definition) of the model or a next generation that is being defined and rolled out with control.
Basic use case walk through
A typical use case would be to update a charm revision, update the config for the new charm revision, and to roll that out such that you can validate it behaves correctly before rolling that change to all units. In our example letâs update Keystone.
$ juju add-generation
target generation set to next
$ juju upgrade-charm keystone
Added charm "cs:keystone-285" to the model.
$ juju config keystone debug=true
With those changes now awaiting rollout to the model in the next generation the user can push it out to units selectively.
$ juju set-generation keystone/0
Additional changes can be made to the next generation.
$ juju config ceph-mon loglevel=10
Note: this change will be visible to keystone/0 immediately, but not to the other units.
And these can be pushed out at the application level as well. The user may also specify multiple targets to the set-generation command.
$ juju set-generation ceph-mon keystone/1 keystone/2
Once the changes in the next generation are all pushed out the generation is deemed to be live and it the target generation becomes current.
$ juju set-generation keystone/3
all changes in next generation complete, target generation set to current
Which model operations are tracked via generations?
Not all changes to the model are tracked in this way.
upgrade-charmconfigattach
These are the operations that can be pinned to a future generation. This might change over time, but anything outside of those operations are considered out of scope for this specification.
Targeting options for pushing to the next generation
The set-generation command takes one or more model targets which may consist of application or unit names. In this way you might update a few related applications, update a select unit of each, and validate your changes are solid.
Added charm "cs:keystone-285" to the model, queued in next generation.
$ juju upgrade-charm percona-cluster
Added charm "cs:percona-cluster-270" to the model, queued in next generation.
$ juju set-generation keystone/0 percona-cluster/0
*manual validation of the updated charms here*
The user can then push out to the rest of the units by just using the application as the target.
$ juju set-generation keystone percona-cluster
Making multiple changes to the next generation
If you set-generation to a unit and later make another change that affects that unit it will be instantly sent out. The idea is that once you set-generation that unit is tracking the next generation and will get live updates.
$ juju set-generation ceph-mon/0
At this point the ceph-mon/0 unit will receive a second config-changed event with the loglevel value of 10.
Making changes that occur immediately and are not related to future generations
Users may switch between the current and next generations.
$ juju switch-generation current
And now changes go out live as they normally would without any need to push them selectively.
Commands can also be scripted to target generations specifically.
$ juju config --generation=current ceph-mon loglevel=1
Cancelling a next generation
If a next generation is not going to be rolled out you can cancel it using the command cancel-generation. This will abort anything in the next generation and return the active target to the current generation.
$ juju cancel-generation
changed dropped and target generation set to current
Note that you cannot cancel a generation with changes that are partially pushed out to only select units. Youâll need to set a value and push to the units involved so that thereâs consistency across the units. You can cancel changes that have not been pushed out. Take the following example:
ERROR: cannot cancel generation, there are units behind a generation: keystone/1, keystone/2
$ juju set-generation keystone/1 keystone/2
At this point all of the Keystone units have the new config but the ceph-mon change has not been pushed to any units. Since they are consistent we can cancel the changes and return to the current generation.
Tracking units not on the up to date generation
When a new generation is added and changes come in status will indicate units that are behind a generation. These units need a set-generation command to get the latest details and become up to date.
$ juju config percona-cluster tuning-level=safest
$ juju status
default jujudemo google/us-east1 2.4.2 unsupported 13:09:59-04:00
keystone/0* blocked executing 0 35.229.100.32 5000/tcp Missing relations: database
keystone/1 blocked executing 1 104.196.99.233 5000/tcp [old] Missing relations: database
keystone/2 blocked executing 2 35.227.24.239 5000/tcp [old](start) Missing relations: database
percona-cluster/0* active idle 3 35.227.60.108 3306/tcp Unit is ready
percona-cluster/1 maintenance executing 4 35.237.241.58 [old] Waiting 30 seconds for operation ...
percona-cluster/2 maintenance executing 5 35.231.140.154 [old] Waiting 60 seconds for operation ...
Note that the units that are on the previous generation are noted as being [old]. These are targets that need to be updated before the transition to the next generation is complete. Note that the indication is on the unit Message field regardless of what the changes made are. A config change, charm upgrade, or resources change will all indicate in the same way. The details about what is different can be investigated using the diff-generation command noted below.
Showing the difference between the current and next generations
Users can see what changes are made to the next generation using the command diff-generation. It will display only those changes that were made since the generation was added. It will not indicate which have been pushed or not. Only the changes made themselves.
$ juju diff-generation
applications:
keystone:
config:
debug: true
ceph-mon:
config:
loglevel: 1
<note: this output format should look like an overlay or something that might be in common with diff-bundle work and such>
