I just tried deploying a lxd cluster with juju
juju deploy lxd --num-units 4 --config mode=cluster --config lxd-listen-https=true
The cluster comes up OK.
When I use that LXD cluster however and deploy 20 containers on it with juju as:
juju deploy ubuntu -n 20
juju (or lxd) doesn’t seem to distribute the deploy, but all containers end up at the same host. The corresponding containers end up in an ERROR state as you can see from my screenshot below (I think this is because my cluster hosts are too small, but I’m not sure):
Is the lxd cluster the problem source here or juju?
