How to integrate with OpenCTI
Wazuh allows integration with OpenCTI through the opencti-connector interface. This enables you to create custom integration scripts that query OpenCTI from Wazuh.
What you’ll do
- Integrate
wazuh-servercharm with theopencticharm. - Create a sample custom integration script to query OpenCTI from Wazuh.
What you’ll need
- An existing
wazuh-serverdeployment. Refer to the Wazuh tutorial on how to deploy Wazuh. - An existing
openctideployment. Refer to the OpenCTI tutorial on the deployment steps.
Integrate OpenCTI with Wazuh
Create an offer from OpenCTI:
juju offer opencti:opencti-connector opencti
Grant the Wazuh model access to the OpenCTI offer:
juju grant <wazuh-model> consume admin/<opencti-model>.opencti
In the Wazuh model, consume the OpenCTI offer:
juju switch <wazuh-model>
juju consume admin/<opencti-model>.opencti
Integrate Wazuh with OpenCTI:
juju integrate wazuh-server:opencti-connector admin/<opencti-model>.opencti
There is currently a limitation in Juju that only the offer side of a cross model relation can share a Juju secret to the other side. Since the OpenCTI charm creates a secret and shares it in the relation data, the Juju offer must be created on OpenCTI model’s side and consumed by the Wazuh model.
Create a custom integration script
Create a custom integration script with custom-opencti- prepended to the name of the script. The
custom-opencti- prefix is required for the charm’s automation to detect the right <integration>
block in ossec.conf and inject the OpenCTI URL and token accordingly.
Add the script under /var/ossec/integrations in your custom configuration repository.
Assign permissions to the custom integration script to ensure it is executable:
chmod 750 /var/ossec/integrations/custom-opencti-script
Add the following configuration block to /var/ossec/bin/ossec.conf:
<integration>
<name>custom-opencti-script</name>
<alert_format>json</alert_format>
<api_key></api_key>
<hook_url></hook_url>
</integration>
Update the wazuh-server configuration to point to a Git reference that includes
your custom script and configuration changes.
juju config wazuh-server custom-config-repository='git+ssh://git@<your-repo-url>@<new-reference>'
Monitor the deployment using juju status until the output looks similar to the following one:
certificates active 1 self-signed-certificates latest/stable 155 10.87.137.125 no
traefik 2.11.0 active 1 traefik-k8s latest/edge 233 10.87.242.226 no Serving at 10.142.2.62
wazuh-server active 1 wazuh-server latest/edge 39 10.87.248.244 no
Ensure the wazuh-server application reaches an Active status.
Congratulations! You’ve successfully configured custom OpenCTI integration scripts in Wazuh.
