Hi,
when I am deploying Charmed Kubernetes on OpenStack in default model, I do have automatically attached volumes to the server instance, because I specified constraint
root-disk-source=volume
in controller bootstrap process.
But when I create different model using
juju add-model <model_name>
and deploy kubernetes there, the server instances doesn’t have volumes attached, which cause failures because of low disk space.
I can’t see any differences between models, where is specified that that volumes should be created or not in model? Or how it works?
Thanks in advance!
Lumir
