The charmcraft team is proud to announce that we’ve just released version 0.8.0 of ops, the Operator Framework for Juju charms.
Changes in this release include:
testing
Harnessupdates-
Harness.begin_with_initial_hooks()will cause the testingHarnessto
emit all of the events that Juju normally does while a charm is
‘starting’. (install,leader-elected, etc.). While most unit tests
should be more focused on a single hook interaction, this gives a bit more
confidence that the whole initialization step of the charm operates in a
good manner. -
Harness.get_pod_spec()allows a test to introspect what pod spec was set
in response to their update event. Eg.,harness = Harness(MyCharm) # ... initial setup harness.begin() harness.update_config({'foo': 'bar'}) pod_spec, k8s_resources = harness.get_pod_spec() self.assertIsNone(k8s_resources) self.assertEqual(pod_spec['blah']['blah'], 'bar') -
Harness.cleanup()is now available to ensure that any temporary
files/directories created by the harness are cleaned up. For unittest you
would use this as:harness = Harness(MyCharm) self.addCleanup(harness.cleanup) ...This is currently only relevant if you are running tests that make use of
resources (eitheradd_oci_resourceoradd_resource). However, it is good
practice to start making use of it, in case there are other resources
associated withHarnessthat will need to be cleaned up. -
Harness.add_resource()is now also available so that you can feed your
charm code file content that it would get fromresource-get.
You no longer need to call
ops.lib.autoimportbefore your first call to
ops.lib.use; you only need to do it if the library information is out of
date (e.g. if you installed or otherwise altered what the system would find).
Also a lot more logging of the process of autodiscovery has been added.
Thanks to @stub42 for pointing out how needing the first call was
counter-intuitive, and the process hard to debug. -
Libraries used via
ops.lib.usecan now have subpackages or modules. -
dispatch-aware charms that setJUJU_DISPATCH_PATHbefore calling into the
framework caused the framework to think the Juju it was running on supported
dispatch, even if the version was clearly too old for that. This meant that
non-initial hooks were never called on these charms on those
Jujus. Unfortunately charms created withcharmcraft0.3 fell into this
category. The framework now looks directly at the Juju version to determine
dispatch support. Thanks to @gnuoy for finding reporting this.
