Velero Operator documentation
Charmed Velero
Charmed Velero is a Juju charm that deploys and manages Velero, an open-source tool for safely backing up and restoring Kubernetes cluster resources and persistent volumes. It provides disaster recovery, cluster migration, and backup and restore for workloads across namespaces, including non-Juju-managed ones.
This charm supports AWS and Azure Kubernetes clusters via S3 and Azure object storage backends. Additionally, the charm exposes Prometheus metrics for observability.
In this documentation
Tutorial
Get started - a hands-on introduction for new users deploying the charmed operator.
How-to guides
Step-by-step guides covering key operations and common tasks.
Explanation
Concepts - discussion and clarification of key topics.
Reference
Technical information - specifications, APIs, architecture.
Project and Community
Charmed Velero is a distribution of Velero. It’s an open-source project that welcomes community contributions, suggestions, fixes and constructive feedback.
License
Charmed Velero is free software distributed under the Apache Software License, version 2.0. For more information, see LICENSE.
Navigation
Mapping table
Level Path Navlink
1 tutorial Tutorial
1 how-to How to
2 integrate-with-cos Integrate with COS
2 integrate-with-azure Integrate with an Azure Kubernetes cluster
2 integrate-with-aws Integrate with an AWS Kubernetes cluster
2 integrate-with-gcp Integrate with a Google Kubernetes cluster
2 restore-charm-pv Restore charm PV
2 backup-config-integration Backup config integration
1 explanation Explanation
2 system-architecture System architecture
2 charm-lifecycle Charm lifecycle
2 file-system-backup File system backup
1 reference Reference
2 backup-config-interface Backup config interface
2 actions Actions
2 configurations Configurations
2 integrations Integrations
2 alert-rules Alert Rules
2 dashboard Grafana Dashboard
Hi,
I’ve configured an s3 storage with a self-signed CA and server certificate.
I’ve used s3-integrator from channel 2, I did use β€œtls-ca-chainβ€œ with my CA file. The s3-integrator is in active state. But velero won’t connect, I am getting this error
httpcore.ConnectError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1000)
This my deployment
user05@mk8s01:~$ juju run s3-integrator/0 status-detail
Running operation 15 with 1 task
  - task 16 on unit-s3-integrator-0
Waiting for task 16...
18:50:30 Stored statuses:
18:50:31                      App Statuses
┃ Status ┃ Component Name ┃ Message ┃ Action ┃ Reason ┃
β”‚ Active β”‚ general        β”‚         β”‚ N/A    β”‚ N/A    β”‚
β”‚ Active β”‚ s3-provider    β”‚         β”‚ N/A    β”‚ N/A    β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”˜
18:50:31                      Unit Statuses
json-output:
  app: '[{"Status": "Active", "Component Name": "general", "Message": "", "Action":
    "N/A", "Reason": "N/A"}, {"Status": "Active", "Component Name": "s3-provider",
    "Message": "", "Action": "N/A", "Reason": "N/A"}]'
  unit: '[{"Status": "Active", "Component Name": "general", "Message": "", "Action":
user05@mk8s01:~$ juju status
Model          Controller  Cloud/Region      Version  SLA          Timestamp
velero-backup  uk8sx       my-k8s/localhost  3.6.21   unsupported  18:50:35Z
App              Version  Status   Scale  Charm            Channel      Rev  Address         Exposed  Message
s3-integrator             active       1  s3-integrator    2/edge       550  10.152.183.105  no
velero-operator           blocked      1  velero-operator  1.15/stable  421  10.152.183.235  no       Velero Storage location is not ready: BackupStorageLocation is unavailable
Unit                Workload  Agent  Address       Ports  Message
s3-integrator/0*    active    idle   10.1.111.113
velero-operator/0*  blocked   idle   10.1.111.118         Velero Storage location is not ready: BackupStorageLocation is unavailable
Is there a way to make it work with a local CA certificate?
Regards.
Can you please open a feature request on github? I don’t think this is supported at the moment, thanks
