Reference
This section provides detailed reference material for the Vault Charm, from secrets engine to support backend and TLS.
In the left sidebar navigation, you will find the following references:
| Page | Description |
| Backend | Storage Backends supported by this charm |
| TLS | Encrypted communication with Vault |
| Unsealing | Unsealing a Vault unit |
| Production Blueprint | Recommended Production deployment |
| S3 storage for backup and restore | S3 for storing Vault backups |
| Relation-based secret engines | Vault secret engines supported through charm integrations |
In the tabs at the top of the page, you can also the following automatically generated API references:
| Integrations | Integration/relation interfaces supported by this charm |
| Libraries | Libraries offered to integrate with the Vault charm |
| Configuration | Application configuration parameters |
| Actions | Juju actions supported by this charm |
