Vault leader got hook failed: "leader-elected" after reboot
Hi,
Environment:
  • Vault Version: 1.8/stable
  • Deployment: Juju Charm
  • Openstack version: Yoga
Description:
The machine running the Vault leader was rebooted, causing the leader role to move to another unit. However, the new leader is reporting a hook failed: "leader-elected" error.
Upon checking the logs, I found the following warning:
$ cat /var/log/juju/unit-vault-1.log | tail
WARNING unit.vault/1.leader-elected logger.go:60 hvac.exceptions.InvalidRequest: backend must be configured with a CA certificate/key, on get http://127.0.0.1:8220/v1/charm-pki-local/cert/ca_chain
ERROR juju.worker.uniter.operation runhook.go:180 hook "leader-elected" (via explicit, bespoke hook script) failed: exit status 1
INFO juju.worker.uniter resolver.go:180 awaiting error resolution for "leader-elected" hook
Vault status :
vault                            1.8.8            error       3  vault                       1.8/stable     372  no       hook failed: "leader-elected"
vault-mysql-router               8.0.45           active      3  mysql-router                8.0/stable     257  no       Unit is ready
vault/0                               active    idle   3/lxd/11  10.10.10.123   8200/tcp        Unit is ready (active: true, mlock: disabled)
  hacluster-vault/1                   active    idle             10.10.10.123                   Unit is ready and clustered
  vault-mysql-router/1*               active    idle             10.10.10.123                   Unit is ready
vault/1*                              error     idle   4/lxd/11  10.10.10.133   8200/tcp        hook failed: "leader-elected"
  hacluster-vault/2*                  active    idle             10.10.10.133                   Unit is ready and clustered
  vault-mysql-router/2                active    idle             10.10.10.133                   Unit is ready
vault/2                               active    idle   5/lxd/11  10.10.10.94    8200/tcp        Unit is ready (active: true, mlock: disabled)
  hacluster-vault/0                   active    idle             10.10.10.94                    Unit is ready and clustered
  vault-mysql-router/0                active    idle             10.10.10.94                    Unit is ready
i’ve also check on all unit and here is the output, only 1 unit that seems normal.
$ juju exec -a vault "curl -s http://127.0.0.1:8220/v1/charm-pki-local/cert/ca_chain"
vault/0:
{"errors":["missing client token"]}
vault/1:
{"errors":["backend must be configured with a CA certificate/key"]}
vault/2:
FYI, CA is already generated. Only unit-0 is normal.
$ juju run vault/0 get-root-ca
Running operation 209 with 1 task
  - task 210 on unit-vault-0
Waiting for task 210...
output: |-
  -----BEGIN CERTIFICATE-----
  MIIDazCCAlOgAwIBAgIUb+u3lDPtTKW5cub769tQU+2hkVswDQYJKoZIhvcNAQEL
lxc
active
lxc
$ juju run vault/1 get-root-ca
Running operation 211 with 1 task
  - task 212 on unit-vault-1
Waiting for task 212...
Action id 212 failed: hvac.exceptions.InvalidRequest: backend must be configured with a CA certificate/key, on get http://127.0.0.1:8220/v1/charm-pki-local/cert/ca_chain
output: |-
lxc
active
Please help.
Thanks.
