Vault hook failed to start
Dear All,
I am finding the error vault hook failed restart.
neutron-api/0* active idle 1/lxd/2 192.168.0.241 9696/tcp Unit is ready
neutron-api-mysql-router/0* active idle 192.168.0.241 Unit is ready
neutron-api-plugin-ovn/0* active idle 192.168.0.241 Unit is ready
nova-cloud-controller/0* active idle 3/lxd/1 192.168.0.244 8774/tcp,8775/tcp Unit is ready
ncc-mysql-router/0* active idle 192.168.0.244 Unit is ready
nova-compute/0* active idle 1 192.168.0.6 Unit is ready
ovn-chassis/2 active idle 192.168.0.6 Unit is ready
nova-compute/1 active idle 2 192.168.0.7 Unit is ready
ovn-chassis/1 active idle 192.168.0.7 Unit is ready
nova-compute/2 active idle 3 192.168.0.8 Unit is ready
ovn-chassis/0* active idle 192.168.0.8 Unit is ready
openstack-dashboard/0* active idle 2/lxd/3 192.168.0.246 80/tcp,443/tcp Unit is ready
dashboard-mysql-router/0* active idle 192.168.0.246 Unit is ready
ovn-central/0* active idle 0/lxd/1 192.168.0.238 6641/tcp,6642/tcp Unit is ready (northd: active)
ovn-central/1 active idle 1/lxd/1 192.168.0.239 6641/tcp,6642/tcp Unit is ready (leader: ovnnb_db, ovnsb_db)
ovn-central/2 active idle 2/lxd/1 192.168.0.240 6641/tcp,6642/tcp Unit is ready
placement/0* active idle 3/lxd/2 192.168.0.245 8778/tcp Unit is ready
placement-mysql-router/0* active idle 192.168.0.245 Unit is ready
rabbitmq-server/0* active idle 2/lxd/2 192.168.0.243 5672/tcp Unit is ready
vault/0* error idle 3/lxd/0 192.168.0.237 8200/tcp hook failed: “start”
vault-mysql-router/0* active idle 192.168.0.237 Unit is ready
Even i restarted the services
juju run-action vault/0 --wait resume but it could be solved the issues
Please help me to rectified this error
Please check the logs of the vault unit:
juju debug-log --replay --no-tail --include vault/0
unit-vault-0: 18:21:00 ERROR unit.vault/0.juju-log Traceback (most recent call last): File “/var/lib/juju/agents/unit-vault-0/charm/actions/resume”, line 231, in main charms.reactive.main() File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/charms/reactive/init.py”, line 74, in main bus.dispatch(restricted=restricted_mode) File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/charms/reactive/bus.py”, line 390, in dispatch _invoke(other_handlers) File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/charms/reactive/bus.py”, line 359, in _invoke handler.invoke() File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/charms/reactive/bus.py”, line 181, in invoke self._action(*args) File “/var/lib/juju/agents/unit-vault-0/charm/reactive/vault_handlers.py”, line 1003, in create_certs bundle = vault_pki.generate_certificate(cert_type, File “/var/lib/juju/agents/unit-vault-0/charm/lib/charm/vault_pki.py”, line 104, in generate_certificate client = vault.get_local_client() File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 339, in wrapped_f return self(f, *args, **kw) File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 430, in call do = self.iter(retry_state=retry_state) File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 367, in iter return fut.result() File “/usr/lib/python3.8/concurrent/futures/_base.py”, line 437, in result return self.__get_result() File “/usr/lib/python3.8/concurrent/futures/_base.py”, line 389, in __get_result raise self._exception File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 433, in call result = fn(*args, **kwargs) File “/var/lib/juju/agents/unit-vault-0/charm/lib/charm/vault.py”, line 254, in get_local_client client.auth_approle(app_role_id) File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/v1/init.py”, line 2072, in auth_approle return self.auth(‘/v1/auth/{0}/login’.format(mount_point), json=params, use_token=use_token) File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/v1/init.py”, line 1726, in auth return self._adapter.auth( File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/adapters.py”, line 159, in auth response = self.post(url, **kwargs).json() File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/adapters.py”, line 103, in post return self.request(‘post’, url, **kwargs) File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/adapters.py”, line 233, in request utils.raise_for_error(response.status_code, text, errors=errors) File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/utils.py”, line 43, in raise_for_error raise exceptions.VaultDown(message, errors=errors) hvac.exceptions.VaultDown: Vault is sealed
unit-vault-0: 18:21:00 INFO unit.vault/0.juju-log DEPRECATION WARNING: Function action_fail is being removed : moved to function_fail() unit-vault-0: 18:21:00 INFO juju.worker.uniter awaiting error resolution for “start” hook
This is the issue. However it is not surfaced in juju status. There, it shows a hook error of hook failed: “start”. Let me investigate.
unit-vault-0: 19:28:36 WARNING unit.vault/0.start Traceback (most recent call last): unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/charm/hooks/start”, line 22, in unit-vault-0: 19:28:36 WARNING unit.vault/0.start main() unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/charms/reactive/init.py”, line 74, in main unit-vault-0: 19:28:36 WARNING unit.vault/0.start bus.dispatch(restricted=restricted_mode) unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/charms/reactive/bus.py”, line 390, in dispatch unit-vault-0: 19:28:36 WARNING unit.vault/0.start _invoke(other_handlers) unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/charms/reactive/bus.py”, line 359, in _invoke unit-vault-0: 19:28:36 WARNING unit.vault/0.start handler.invoke() unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/charms/reactive/bus.py”, line 181, in invoke unit-vault-0: 19:28:36 WARNING unit.vault/0.start self._action(*args) unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/charm/reactive/vault_handlers.py”, line 1003, in create_certs unit-vault-0: 19:28:36 WARNING unit.vault/0.start bundle = vault_pki.generate_certificate(cert_type, unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/charm/lib/charm/vault_pki.py”, line 104, in generate_certificate unit-vault-0: 19:28:36 WARNING unit.vault/0.start client = vault.get_local_client() unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 339, in wrapped_f unit-vault-0: 19:28:36 WARNING unit.vault/0.start return self(f, *args, **kw) unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 430, in call unit-vault-0: 19:28:36 WARNING unit.vault/0.start do = self.iter(retry_state=retry_state) unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 367, in iter unit-vault-0: 19:28:36 WARNING unit.vault/0.start return fut.result() unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/usr/lib/python3.8/concurrent/futures/_base.py”, line 437, in result unit-vault-0: 19:28:36 WARNING unit.vault/0.start return self.__get_result() unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/usr/lib/python3.8/concurrent/futures/_base.py”, line 389, in __get_result unit-vault-0: 19:28:36 WARNING unit.vault/0.start raise self._exception unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 433, in call unit-vault-0: 19:28:36 WARNING unit.vault/0.start result = fn(*args, **kwargs) unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/charm/lib/charm/vault.py”, line 254, in get_local_client unit-vault-0: 19:28:36 WARNING unit.vault/0.start client.auth_approle(app_role_id) unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/v1/init.py”, line 2072, in auth_approle unit-vault-0: 19:28:36 WARNING unit.vault/0.start return self.auth(‘/v1/auth/{0}/login’.format(mount_point), json=params, use_token=use_token) unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/v1/init.py”, line 1726, in auth unit-vault-0: 19:28:36 WARNING unit.vault/0.start return self._adapter.auth( unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/adapters.py”, line 159, in auth unit-vault-0: 19:28:36 WARNING unit.vault/0.start response = self.post(url, **kwargs).json() unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/adapters.py”, line 103, in post unit-vault-0: 19:28:36 WARNING unit.vault/0.start return self.request(‘post’, url, **kwargs) unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/adapters.py”, line 233, in request unit-vault-0: 19:28:36 WARNING unit.vault/0.start utils.raise_for_error(response.status_code, text, errors=errors) unit-vault-0: 19:28:36 WARNING unit.vault/0.start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/utils.py”, line 43, in raise_for_error unit-vault-0: 19:28:36 WARNING unit.vault/0.start raise exceptions.VaultDown(message, errors=errors) unit-vault-0: 19:28:36 WARNING unit.vault/0.start hvac.exceptions.VaultDown: Vault is sealed unit-vault-0: 19:28:37 ERROR juju.worker.uniter.operation hook “start” (via explicit, bespoke hook script) failed: exit status 1 unit-vault-0: 19:28:37 INFO juju.worker.uniter awaiting error resolution for “start” hook unit-vault-0: 19:31:57 INFO juju.worker.uniter awaiting error resolution for “start” hook
The stacktrace in the log you provided is from the resume action but the issue surfaced in juju status is a failed start hook. It would be great if you could capture that.
Can you also give the full output to juju status --relations vault?
Sir,
FYI
root@maassrv:~# juju status --relations vault Model Controller Cloud/Region Version SLA Timestamp openstack juju-controller maassrv/default 2.9.14 unsupported 20:14:01+05:30
App Version Status Scale Charm Store Channel Rev OS Message vault 1.5.9 blocked 1 vault charmhub stable 50 ubuntu Unit is sealed vault-mysql-router 8.0.26 active 1 mysql-router charmhub stable 11 ubuntu Unit is ready
Unit Workload Agent Machine Public address Ports Message vault/0* blocked executing 3/lxd/0 192.168.0.237 8200/tcp (start) Unit is sealed vault-mysql-router/0* active idle 192.168.0.237 Unit is ready
Machine State DNS Inst id Series AZ Message 3 started 192.168.0.8 HP-04 focal default Deployed 3/lxd/0 started 192.168.0.237 juju-e45ffe-3-lxd-0 focal default Container started
Relation provider Requirer Interface Type Message mysql-innodb-cluster:db-router vault-mysql-router:db-router mysql-router regular vault-mysql-router:shared-db vault:shared-db mysql-shared subordinate vault:certificates cinder:certificates tls-certificates regular vault:certificates glance:certificates tls-certificates regular vault:certificates keystone:certificates tls-certificates regular vault:certificates mysql-innodb-cluster:certificates tls-certificates regular vault:certificates neutron-api-plugin-ovn:certificates tls-certificates regular vault:certificates neutron-api:certificates tls-certificates regular vault:certificates nova-cloud-controller:certificates tls-certificates regular vault:certificates openstack-dashboard:certificates tls-certificates regular vault:certificates ovn-central:certificates tls-certificates regular vault:certificates ovn-chassis:certificates tls-certificates regular vault:certificates placement:certificates tls-certificates regular vault:cluster vault:cluster vault-ha peer
root@maassrv:~#
openstack juju-controller maassrv/default 2.9.14 unsupported 20:15:34+05:30
vault 1.5.9 error 1 vault charmhub stable 50 ubuntu hook failed: “start”
root@maassrv:~#
Please stand by for an update in the next couple of hours. Thanks for your patience.
Hi @prajwalvinu, I suspect you are using the config option totally-unsecure-auto-unlock, otherwise the start hook, which is failing in your case, wouldn’t be “surprised” by a sealed vault, and would just “wait” for you to go through the manual procedure for unsealing. Can you please show us the output of this in order to validate my assumption?
juju config vault totally-unsecure-auto-unlock
I think you did everything right but this option is known to have some rough edges and when it goes wrong, it’s hard to get out of this state. If you can, I would recommend tearing down your deployment and trying again, and I would recommend not using this option and instead going through the secure procedure for unsealing the vault. I believe this is a brand new deployment, correct? Otherwise it wouldn’t be running the start hook I believe.
If you still want to try rescuing your current deployment, I would personally try the following things, but I can’t promise this will work:
# Get the unit out of the error state:
juju resolve --no-retry vault/0
# At this point the vault is still sealed and I believe we have no
# choice but to go through the manual procedure in order to
# unseal it. First let's disable the automatic unsealing:
juju config vault totally-unsecure-auto-unlock=false
# The procedure is best described at https://charmhub.io/vault
# and will look like:
snap install vault
export VAULT_ADDR="http://<unit-ip>:8200"
vault operator init -key-shares=5 -key-threshold=3
vault operator unseal <key-1>
vault operator unseal <key-2>
vault operator unseal <key-3>
export VAULT_TOKEN=<token>
vault token create -ttl=10m
juju run-action --wait vault/0 authorize-charm token=<token>
I hope this helps.
Hi sir @aurelien-lourot
Thank you very much it is active now
root@maassrv:~# juju status vault Model Controller Cloud/Region Version SLA Timestamp openstack juju-controller maassrv/default 2.9.14 unsupported 10:53:59+05:30
App Version Status Scale Charm Store Channel Rev OS Message vault 1.5.9 active 1 vault charmhub stable 50 ubuntu Unit is ready (active: true, mlock: disabled) vault-mysql-router 8.0.26 active 1 mysql-router charmhub stable 11 ubuntu Unit is ready
Unit Workload Agent Machine Public address Ports Message vault/0* active idle 3/lxd/0 192.168.0.237 8200/tcp Unit is ready (active: true, mlock: disabled) vault-mysql-router/0* active idle 192.168.0.237 Unit is ready
Sir @aurelien-lourot
When the server get restarted vault status would be blocked and showing unit sealed and how do i make that active state ? vault/0* blocked idle 3/lxd/0 192.168.0.237 8200/tcp Unit is sealed
Hi @prajwalvinu, this is by security design: when you restart the vault (or the server it’s running on), it gets sealed and requires manual intervention to unseal it. See our unsealing procedure and also the upstream documentation about this topic.
Thank you for support sir
Even the mysql-innodb-cluster showing that cluster is inaccessible.
and tired to resume using this commands
juju run-action --wait mysql-innodb-cluster/0 resume and reboot-complete-outage
also still its showing blocked state
mysql-innodb-cluster 8.0.26 blocked 3 mysql-innodb-cluster charmhub stable 11 ubuntu Cluster is inaccessible from this instance. Please check logs for details.
mysql-innodb-cluster/0* blocked idle 0/lxd/0 192.168.0.9 Cluster is inaccessible from this instance. Please check logs for details.
mysql-innodb-cluster/1 blocked idle 1/lxd/0 192.168.0.235 Cluster is inaccessible from this instance. Please check logs for details.
mysql-innodb-cluster/2 blocked idle 2/lxd/0 192.168.0.236 Cluster is inaccessible from this instance. Please check logs for details.
