After a a server shoot down the valve is no starting again.with the error
vault 1.5.4 error 1 vault charmstore 44 ubuntu hook failed: “start”
I am attaching part of the log file.
2021-06-10 13:12:03 WARNING start Traceback (most recent call last):
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/urllib3/connection.py”, line 169, in _new_conn
2021-06-10 13:12:03 WARNING start conn = connection.create_connection(
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/urllib3/util/connection.py”, line 96, in create_connection
2021-06-10 13:12:03 WARNING start raise err
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/urllib3/util/connection.py”, line 86, in create_connection
2021-06-10 13:12:03 WARNING start sock.connect(sa)
2021-06-10 13:12:03 WARNING start ConnectionRefusedError: [Errno 111] Connection refused
2021-06-10 13:12:03 WARNING start During handling of the above exception, another exception occurred:
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 699, in urlopen
2021-06-10 13:12:03 WARNING start httplib_response = self._make_request(
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 394, in _make_request
2021-06-10 13:12:03 WARNING start conn.request(method, url, **httplib_request_kw)
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/urllib3/connection.py”, line 234, in request
2021-06-10 13:12:03 WARNING start super(HTTPConnection, self).request(method, url, body=body, headers=headers)
2021-06-10 13:12:03 WARNING start File “/usr/lib/python3.8/http/client.py”, line 1255, in request
2021-06-10 13:12:03 WARNING start self._send_request(method, url, body, headers, encode_chunked)
2021-06-10 13:12:03 WARNING start File “/usr/lib/python3.8/http/client.py”, line 1301, in _send_request
2021-06-10 13:12:03 WARNING start self.endheaders(body, encode_chunked=encode_chunked)
2021-06-10 13:12:03 WARNING start File “/usr/lib/python3.8/http/client.py”, line 1250, in endheaders
2021-06-10 13:12:03 WARNING start self._send_output(message_body, encode_chunked=encode_chunked)
2021-06-10 13:12:03 WARNING start File “/usr/lib/python3.8/http/client.py”, line 1010, in _send_output
2021-06-10 13:12:03 WARNING start self.send(msg)
2021-06-10 13:12:03 WARNING start File “/usr/lib/python3.8/http/client.py”, line 950, in send
2021-06-10 13:12:03 WARNING start self.connect()
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/urllib3/connection.py”, line 200, in connect
2021-06-10 13:12:03 WARNING start conn = self._new_conn()
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/urllib3/connection.py”, line 181, in _new_conn
2021-06-10 13:12:03 WARNING start raise NewConnectionError(
2021-06-10 13:12:03 WARNING start urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f3a1804a160>: Failed to establish a new connection: [Errno 111] Connection refused
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/requests/adapters.py”, line 439, in send
2021-06-10 13:12:03 WARNING start resp = conn.urlopen(
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 755, in urlopen
2021-06-10 13:12:03 WARNING start retries = retries.increment(
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/urllib3/util/retry.py”, line 573, in increment
2021-06-10 13:12:03 WARNING start raise MaxRetryError(_pool, url, error or ResponseError(cause))
2021-06-10 13:12:03 WARNING start urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host=‘127.0.0.1’, port=8220): Max retries exceeded with url: /v1/auth/approle/login (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x7f3a1804a160>: Failed to establish a new connection: [Errno 111] Connection refused’))
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/charm/hooks/start”, line 22, in
2021-06-10 13:12:03 WARNING start main()
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/charms/reactive/init.py”, line 74, in main
2021-06-10 13:12:03 WARNING start bus.dispatch(restricted=restricted_mode)
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/charms/reactive/bus.py”, line 390, in dispatch
2021-06-10 13:12:03 WARNING start _invoke(other_handlers)
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/charms/reactive/bus.py”, line 359, in _invoke
2021-06-10 13:12:03 WARNING start handler.invoke()
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/charms/reactive/bus.py”, line 181, in invoke
2021-06-10 13:12:03 WARNING start self._action(*args)
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/charm/reactive/vault_handlers.py”, line 846, in publish_ca_info
2021-06-10 13:12:03 WARNING start if not client_approle_authorized():
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/charm/reactive/vault_handlers.py”, line 789, in client_approle_authorized
2021-06-10 13:12:03 WARNING start vault.get_local_client()
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 333, in wrapped_f
2021-06-10 13:12:03 WARNING start return self(f, *args, **kw)
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 423, in call
2021-06-10 13:12:03 WARNING start do = self.iter(retry_state=retry_state)
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 360, in iter
2021-06-10 13:12:03 WARNING start return fut.result()
2021-06-10 13:12:03 WARNING start File “/usr/lib/python3.8/concurrent/futures/_base.py”, line 432, in result
2021-06-10 13:12:03 WARNING start return self.__get_result()
2021-06-10 13:12:03 WARNING start File “/usr/lib/python3.8/concurrent/futures/_base.py”, line 388, in __get_result
2021-06-10 13:12:03 WARNING start raise self._exception
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 426, in call
2021-06-10 13:12:03 WARNING start result = fn(*args, **kwargs)
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/charm/lib/charm/vault.py”, line 254, in get_local_client
2021-06-10 13:12:03 WARNING start client.auth_approle(app_role_id)
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/v1/init.py”, line 2072, in auth_approle
2021-06-10 13:12:03 WARNING start return self.auth(’/v1/auth/{0}/login’.format(mount_point), json=params, use_token=use_token)
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/v1/init.py”, line 1726, in auth
2021-06-10 13:12:03 WARNING start return self._adapter.auth(
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/adapters.py”, line 159, in auth
2021-06-10 13:12:03 WARNING start response = self.post(url, **kwargs).json()
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/adapters.py”, line 103, in post
2021-06-10 13:12:03 WARNING start return self.request(‘post’, url, **kwargs)
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/hvac/adapters.py”, line 218, in request
2021-06-10 13:12:03 WARNING start response = self.session.request(method, url, headers=headers,
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/requests/sessions.py”, line 542, in request
2021-06-10 13:12:03 WARNING start resp = self.send(prep, **send_kwargs)
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/requests/sessions.py”, line 655, in send
2021-06-10 13:12:03 WARNING start r = adapter.send(request, **kwargs)
2021-06-10 13:12:03 WARNING start File “/var/lib/juju/agents/unit-vault-0/.venv/lib/python3.8/site-packages/requests/adapters.py”, line 516, in send
2021-06-10 13:12:03 WARNING start raise ConnectionError(e, request=request)
2021-06-10 13:12:03 WARNING start requests.exceptions.ConnectionError: HTTPConnectionPool(host=‘127.0.0.1’, port=8220): Max retries exceeded with url: /v1/auth/approle/login (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x7f3a1804a160>: Failed to establish a new connection: [Errno 111] Connection refused’))
2021-06-10 13:12:03 ERROR juju.worker.uniter.operation runhook.go:136 hook “start” (via explicit, bespoke hook script) failed: exit status 1
2021-06-10 13:12:03 INFO juju.worker.uniter resolver.go:143 awaiting error resolution for “start” hook
